How to retrofit flex floor Astra-J (MK6) 5 Door
Here is a list of the parts needed.
*Please note parts prices vary from dealer to dealer these are the prices I paid.*
[TABLE=Flex Floor Price list]
[TR]
[TD]Part Number[/TD]
[TD]Description[/TD]
[TD]Quantity[/TD]
[TD]Price[/TD]
[TD][b]Cheaper pric
How-to remove front bumper from Astra-j (MK6 5 Door Facelift)
[align=center]How-to remove front bumper from Astra-j (MK6 5 Door Facelift)
Tools needed
*Trim tools
*Torx 10 bit
*Socket Set
The first thing you need to do is remove 3 torx 10 screws on each side of the wheel arch.
[Image: https://www.vxoc.org.uk/Images/rusty/How...mper/1.JPG]
Then there is small bolt where the bumper
Upgrade to alloy door pins
HOW TO CHANGE DOOR PINS
Possibly the Cheapest Upgrade Here
and a very easy and Simple job to do 5 Minutes Max.
Just Unscrew the Original Plastic Door Pins by hand
and Turn the New ones Back in.
[Image: http://i179.photobucket.com/albums/w301/...5690d8.jpg]
[Image: http://i179.photobucket.com/albums/w301/...d47629.jpg]
They c
How-to remove Window trims & door mirrors
[align=center][Image: https://www.vxoc.org.uk/Images/vxoc%20as...x.o.c.jpeg]
How-to remove Window covers & door mirrors
Tools needed
*Trim tools
*Phillips Cross head
*10mm Socket
if replacing the mirror/s you will need to remove the door cards How-to Here.
So to start this is what we have (you may not have wind deflectors fitted).
[img]https://w
How to ambient door lights
This is a How To for the Door Ambient LED Lights
There are now two Versions of this How to so this is Version one
Using the Correct LED but Taking Power
from the Window Switch Ambient Light Circuit
this means they will come on when you Open the Door
and go off when you Close the Door
and stay on when you Turn the Side Lights or Headlights on
i have my Lights wired like t
How to remove door cards
How To Remove Door cards.
Front
[Image: https://www.vxoc.org.uk/Images/rusty/Doo...ront/0.JPG]
The first thing you need to do is open the window/s and remove key.
Then you can start removing the door cards,
So get a small precision screwdriver and remove the cover on behind the door handle
[img]https:
Spoiler for 5 door
Where can I get a genuine astra spoiler that adds quite a bit of definition to the rear of the car? Links plz
Astra 5 door spoiler
Wanting a spoiler for my astra j, want a genuine vx one.
5 door astra j lower grille
Wanting this cheap as chips plz
Which do you prefer, 5 door or GTC
Simple, let's have a vote!!
