JohnL - Replies:
Error showing up when selecting General options
Tested in IE, Firefox and Chrome. Get the following issues when selecting "Forum Actions"-> "General Settings" you get the following error
"Warning: fetch_template() calls should be replaced by the vB_Template class. Template name: userfield_select_option in [path]/includes/functions.php on line 4734
P**** error: syntax error, unexpected T_CONSTANT_ENCAPSED_STRING in /home/sites/vxoc.org.uk/public_html/forum/profile.php(4822) : eval()'d code(23) : eval()'d code on line 1
Warning: fetc
Copy and paste error message
I'm trying to copy and paste a how-to I made on another forum but am unable to paste anything onto this site. I keep getting message " You are not allowed to Copy content from this forum"
Is this a permissions thing or a site rule
tucpal - Replies:
Led drls error free fitted
tucpal - Replies:
HOW-TO LED DRL Error free for the Astra-J 5 door
[align=center][Image:
HOW TO FOR THE LED DRL ERROR FREE BULBS FOR THE ASTRA J 5 DOOR.
INFO.........
The GTC does not need load resisters the LED bulbs will be plug and play error free.
This is what you will need for the LED DRLS.
Two LED DRL bulbs. 7443. 50/50
four 50w 6,ohm Load Resisters.
some clips x8 or solder and shrink wrap optional.
and some ex
Torque APP Error codes
does anyone know what 'fuel system monitor bank 1 min 10,432minute max 40,992minute current 6,624 minute' means???
Error when opening tabs
Still getting this problem on android devices, tried it on 3, iPad works fine
LED Canbus No Error Number Plate Bulbs
Kris - Replies:
HID Error
Anyone know if theres a reason why my car just said check left and right dipped beam lights?? Ive had his installed for a week now and they've been great with no errors. Just took the car out and when auto lights came on i had the errors. Thought it was weird. But I've tried and tried again to get the error back up now and cant since I've stopped and re-started the car.
del - Replies:
H7 error
Hi all
I changed my h7 bulbs on my 5 door biturbo for these
http://pages.ebay.com/link/?nav=item.vie...82&alt=web
And now I am getting check bulb error. I thought it would be a straight swap as there h7 aswel. Does this mean I need to get resistors also? Any help would be great
TIA
Sent from my SM-G925F using Tapatalk
sometimes P2598 error appears, egr?
It's been a week since a P2598 error has appeared in 1.7cdti, sometimes.
I think that wearing the strangled egr can help the bug appear, but I've been with it for almost a year and it did not give me problems.
I have already cleaned MAF and MAP, it has improved but in some cases the fault appears again.
A little help please.
Some shoots...
3200 rpm
[Image:
https://i58.servimg.com/u/f58/19/64/91/07/whatsa28.jpg ]
Medium torque
[img=500x281]https://i58.servimg.com/u/f58/19/64/
