how to upgrade interior lights to SMD LED
This is a very Simply and Cheep Upgrade
How to Upgrade interior Lights to SMD LED BULBS.
[Image: http://www.vxoc.org.uk/Images/tucpal/How...ghts/1.JPG]
STEP ONE..........
Start with the sun Visors all you need to do is to Remove
the two Plastic pieces to get Access to the Bulbs
Gently Pull from one Side
and swap th
led lights on when unlocking
I have daytime LED running lights. I am wondering if i can make them go on when i unlock my car.
My collegue's car, who parks next to me has this on his seat leon.
It looks nice when it's dark and could be handy for finding my car (when parked in big lots)
OEM Led strip headlights upgrade. Astra J
I was driving along today and a red astra J pre facelift 59 plate had the new style led strip in the headlight.
Is this an upgrade or where they available from new from the beginning.
How-to Led Number Plate Lamps
Here is a How-to Led Number Plate Lamps
for the Astra J 5 Door Error Free.
They can be Found on ebay.
[url=http://www.ebay.co.uk/itm/LED-LICENSE-NUMBER-PLATE-LIGHT-VAUXHALL-OPEL-CORSA-C-D-ASTRA-H-J-INSIGNIA-VECTRA-/181596661960?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a480128c8]http://www.ebay.co.uk/itm/LED-LICENSE-NUMBER-PLATE-LIGHT-VAUXHALL-OPEL-CORSA-C-D-A
How-to led reverse light
THIS IS A HOW TO AND REVIEW OF THE SMD LED REVERSE LIGHT BULB
FOR THE ASTRA J 5 DOOR.
So here are the SMD LED Bulb
that is a Direct Replacement for the Standard Bulb
it looks very well made and it is also Really Bright
and also Error Free.
[Image: http://i179.photobucket.com/albums/w301/...0c8aca.jpg]
[img]http://i179.photobucket.com/album
Led drls error free fitted
Well you may know i have been on a bit of a LED mission this weekend
i now have the led reverse light fitted error free
http://www.vxoc.org.uk/forum/Thread-How-...erse-light
and the led number plate led units also done
http://www.vxoc.org.uk/forum/Thread-How-...late-Lamps
and also i have just fitted the LED DRL,S to the astra j 5 door at last and they are also error free
[img]http://i179.photobucket.com/albums/w301/tucpal/ledfuin001_zpsf3237768.jpg[/
Gear surround LED colour change
For anyone that wishes to change the colour of the SMD LED in the gear surround.
Tools required
Stubby Philips s/driver
Small flat blade s/driver
Fine tip soldering iron
Qty 2 [url=http://www.ebay.co.uk/sch/m.html?_odkw=4040+smd&item=271177853516&pt=UK_BOI_Electrical_Components_Supplies_ET&_osacat=0&_from=R40&hash=item3f2375aa4c&_ssn=top-quality-tools&_trksid=p2046732.m570.l1313.TR0.TRC0.H0.X4040
Window switch LED colour change
For any member wanting to change the LED colour in the window switch
Tools required
T20 torx driver
Small flat head
As required 10 x 0805 Blue LED (SMD) - Ultra Bright - UK - 1st Class Post | eBay]805 smd LED One led in both rear and passengers switches. Drivers 2 leds(front elec only) or 5 leds(fr
HOW-TO LED DRL Error free for the Astra-J 5 door
HOW TO FOR THE LED DRL ERROR FREE BULBS FOR THE ASTRA J 5 DOOR.
INFO.........
The GTC does not need load resisters the LED bulbs will be plug and play error free.
This is what you will need for the LED DRLS.
Two LED DRL bulbs. 7443. 50/50
four 50w 6,ohm Load Resisters.
some clips x8 or solder and shrink wrap optional.
and some ex
Heater Panel LED Conversion
Tools required
7mm socket
Qty 14 805 10 x 0805 Blue LED (SMD) - Ultra Bright - UK - 1st Class Post | eBay and 1 PLCC-2 [url=http://www.e
