tucpal - Replies:
Best drl options j and gtc.
[align=center][Image:
There are some good and some bad options out there for the DRL bulbs
i will cover the best options here.
....The Standard DRL bulbs.....
As you will all know are yellow and Dull
and not really up to the job of being a DRL
what more can i say apart from they fit good and that is about it.
W21/5W (580).
[img]http://i179.
tucpal - Replies:
How to change drl and h7 bulbs
This How to will Cover How to change the DRL BULB AND THE H7 BULBS.
Most will know How to Do this but it will Help those that Don't.
FIRST STEP.......
Left Hand side
Remove the Hose from the Air Filter then Pull the Air Filter Box out
and Place it some were Safe out of the way
your Air Hose may be at the Other end of the Air Filter
but do the S
tucpal - Replies:
HOW-TO LED DRL Error free for the Astra-J 5 door
HOW TO FOR THE LED DRL ERROR FREE BULBS FOR THE ASTRA J 5 DOOR.
INFO.........
The GTC does not need load resisters the LED bulbs will be plug and play error free.
This is what you will need for the LED DRLS.
Two LED DRL bulbs. 7443. 50/50
four 50w 6,ohm Load Resisters.
some clips x8 or solder and shrink wrap optional.
and some ex
DRL cover (cap) .. I've lost it :(
I was switching over my DRL's on Sunday afternoon upgrading them to PolarG's and I assumed that I had securely put on the cap, only noticing after washing the car my headlight had condensation inside.. I must not have put the cap on properly and it's dropped out the engine bay and is currently in destination unknown..
Where can I get a spare?!
Drl playing up
[MENTION=2]tucpal[/MENTION] at the weekend me and Dicko took the light out and retrieved the dropped led in the light. When we put the new bulbs in the work fine on DRL with no errors but on side light and main been they just switch off, tried another bulb and the same happened, also the rear tail lights on that side arnt working now! Should I just take the resistor off until u next see you or can you tell me what to do?
DRL indicators
I was thinking in work today would you be able to put indicators into the DRL? The main reason I thought this was my mirrors don't have indicators only low down (where fogs are)
tucpal - Replies:
LED DRL
tucpal - Replies:
W21/5W (580).
[img]http://i179.ph
New LED DRL's showing numerous faults
I have fitted (as per Tucpal's 'How to LED DRL error free' guide) but I am having a headache with faults that have thrown up. I have installed the resistors, wiring and Scotchlok clips and LED bulbs correctly. Firstly, the left DRL will light intermittlently but it will light on the sidelight OK.
And now the following faults show intermittently:
Check left dipped beam lamp
Check right dipped beam lamp
Check left Daylight running lamp
Check right Daylight running lamp
When the lights are swi
Updated DRL lights
My Astra has still not arrived, however driving to work this morning a J came toward me with what looked like OEM DRLs. Would these units fit into my 2012 model (when it arrives) without any issues?
Sorry if this has already been asked before. When searching on DRLs it pulls up 1001 results
Sent from my Samsung Galaxy Tab S 10.5 using Tapatalk
