| Welcome, Guest |
| Latest Threads |
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
Factory Reverse Camera, A...
Forum: Retrofit How-to's
Last Post: obsidian
30:th-Aug-2025, 20:00:16
» Replies: 34
| Remap company |
Posted by: Kiel0777 - 16:th-Dec-2020, 14:29:43 - Forum: Mechanical
- Replies (9)
Looking to get a remap and dyno run done
There's a company in Barnsley that can do a map and dyno for £150.
Company is called carlton tuning?
| Navi650, mic not working |
Posted by: Markt82 - 15:th-Dec-2020, 17:51:56 - Forum: Retrofit Research
- Replies (9)
Hi, just done a navi650 swap from cd400, all good and an Intellilink navi650, however the microphone does not work, I put the mic wires directly into the pins 6 and 16 of the A11 socket, tried them both ways round and nothing, nobody can hear me via Bluetooth, any suggestions with this? Thank you
Mark
| Headlight Switch Disassemble |
Posted by: Jetcolour - 13:th-Dec-2020, 09:32:54 - Forum: Request for information
- Replies (3)
Morning, just wondering if someone knows how to get the headlight switch assembly apart? I'm taking it apart to change the led's in it. Not 100% how it comes apart and don't want to force/break it. Tried looking on the forum but couldn't find anything.
| Astra J Keyfob range |
Posted by: Arkanggel10 - 12:th-Dec-2020, 18:43:53 - Forum: Astra-J/GTC
- Replies (2)
hi guys
My keyfob and spare normal key has very short range to unlock/lock vehicle. i must be within 2m from car to work.
Already replaced both battery's
is there anything that i can try in order to fix this issue?
thanks
| Astra J Total power loss |
Posted by: Galway11 - 6:th-Dec-2020, 21:15:42 - Forum: Astra-J/GTC Technical
- Replies (2)
I had total power loss in my 2013 reg astra J sri .
There was a problem when i drove the car in that the power steering was very hard to turn steering wheel but then back to normal.
!0 minutes later suddenly All power went on the car without warning.. No lights, engine died, total power loss...
Tried jump starting but still nothing happens & all connections to battery seem ok...
Only thing i can think of is that i got battery changed 3 weeks ago so maybe a loose wire somewhere.
Could it be alternator or what else can cause a total loss of power.
Car parked up now & waiting to go to garage tomorrow .....
| Underseat Subwoofer |
Posted by: Jetcolour - 5:th-Dec-2020, 08:43:29 - Forum: ICE
- Replies (1)
I have been toying with the idea off fitting a sub in my car for a while now. I don't find the sound quality bad on the standard set up, just that it lacks some bass.
I was thinking off a slim sub and amp in the boot but have decided against it due to needing the space still.
I am now looking at a underseat subwoofer now. Won't be as bassey as one in the boot, but think it will still add more than it is now.
I've been looking at this:
https://www.caraudiocentre.co.uk/product...-31239.htm
Comes with wiring kit and can be connect into the speaker wires direct.
Has anyone had a underseat sub set up before?
| How remove Flex Ride |
Posted by: Sergio Pinto - 4:th-Dec-2020, 09:15:14 - Forum: Mechanical How-to's
- No Replies
Sorry for my English, I'm from Portugal.
I have an Astra J 2011 1.6 turbo, I would like to remove the shock absorbers and the system (Flex ride) without giving errors.
Can help me.
