issue sidelamp drl
DRL - sidelamp issue
Hello,
I have a code 22 on my screen, which is pretty annoying. The right side lamp is working fine (both of them, left too).
I have already done:
- removed the bulb from the left side: (code 21 come out, which is expected)
- swap the two bulbs left and right side, both working, got error 22 back.
- bought new bulbs, still error 22
What I noticed, sometimes, I don't have error code 22, before I put the bulb with the holder into the lamp, and comes back a little later.
Also noticed the holder is a bit worn out. I tried to make sure the pins connected to the bulb well.
Has somebody come with an issue like this before?
Can somebody suggest a place (online) or in London where I can buy a replacement bulb holder? (the ones I found online looks different)
Try turning the bulb round in the holder.
You can't buy a replacement bulb holder.
You can using a tool carefully close the gap.
Also you can try cleaning the contact area.
  DRL/Sidelight Issue MassiveRoy 1 2,134 10:th-Feb-2021, 19:57:52
Last Post: Rhun91
  2 days and already an issue..... MrCrunchy 6 3,140 18:th-Sep-2020, 18:32:29
Last Post: MrCrunchy
  Aftermarket android H5754 headunit issue simpledun 1 2,723 4:th-Jun-2020, 09:17:15
  ASTRA J HEADUNIT ISSUE AstraJ_OwnerSK 1 2,386 10:th-Nov-2019, 08:31:13
  Sat Nav issue Slakky 3 3,319 2:nd-Sep-2019, 13:06:06
Last Post: vocky
  StabiliTrak/ABS Issue Desperado 1 3,153 17:th-Jun-2019, 09:31:05
  hatch issue Qaranc 4 3,816 2:nd-Jun-2019, 08:01:28
  Tailgate issue Qaranc 0 2,774 1:st-Jun-2019, 09:24:16
Last Post: Qaranc
  Start up issue... only once daveloz12 4 4,198 22:nd-Mar-2019, 10:02:26
Last Post: daveloz12
  Heater Issue StewieG 1 3,028 16:th-Feb-2019, 08:59:18
greg848484 (21:st-Mar-2024, 20:29:47)
