issue sidelight drl
DRL/Sidelight Issue
Apologies if this is in the wrong section, this is my first post..
I've recently got myself a 63plate GTC and noticed last night one of the sidelights is not working.
The bulbs are LED and I understand they function as both the DRL and Sidelights..
With the lights switched off, both DRLs are on, as they should be, but when I switch to sidelights, the driver side dims to sidelight, whilst the passenger side goes off completely.
What would be causing the LEDs to switch off rather than just Dim, is this a case of get new bulbs, or might there be another issue?
Many thanks in advance.
Sounds like a duff bulb to me. You could always take the good bulb out the other side and test it in the other side to make sure it's just the bulb.
  DRL - sidelamp issue stajerad 1 4,370 12:th-Sep-2021, 15:37:54
  2 days and already an issue..... MrCrunchy 6 7,160 18:th-Sep-2020, 18:32:29
Last Post: MrCrunchy
  Aftermarket android H5754 headunit issue simpledun 1 5,013 4:th-Jun-2020, 09:17:15
  ASTRA J HEADUNIT ISSUE AstraJ_OwnerSK 1 4,663 10:th-Nov-2019, 08:31:13
  Sat Nav issue Slakky 3 6,360 2:nd-Sep-2019, 13:06:06
Last Post: vocky
  StabiliTrak/ABS Issue Desperado 1 5,948 17:th-Jun-2019, 09:31:05
  hatch issue Qaranc 4 9,368 2:nd-Jun-2019, 08:01:28
  Tailgate issue Qaranc 0 4,112 1:st-Jun-2019, 09:24:16
Last Post: Qaranc
  Start up issue... only once daveloz12 4 7,536 22:nd-Mar-2019, 10:02:26
Last Post: daveloz12
  Heater Issue StewieG 1 5,342 16:th-Feb-2019, 08:59:18
