Blower issue
im having issue with my blowers.
Basically whats happening when i press the button on control panel to stop or start blowers in one or two areas its not doing anything. Now on the control panel all the buttons work and light up. When pressing the three buttons in the dash displays show the message with arrows etc yet its not stopping or starting any blowers.
I have checked the fuses none are broken.
Thoughts?
Tapatalk issue
I use Tapatalk alot for viewing the site but since the latest update to the site I'm not getting any notifications coming through on my phone. Other sites I use Tapatalk for are working ok. Notifications are set to on.
Anyone else got the same issue or can help
Another blower issue..
Astra J 2010 1.4T Elite climate air direction selection-mind of its own problem!
[quote]
Hi everyone,
I have a 2010 Astra J 1.4T elite with dual zone climate control.
In AUTO mode, everything seems to work correctly, controls temp and directs air to windscreen vents, middle vents and footwell vents.
However if you manually select the air direction (the manual says all combinations are possible) by using the selector buttons, the individual buttons light up, the display shows that they ha
Radiator Fan and Service TAG Issue
Hi all.
Just had my car serviced today, they said they cannot reset the service notice as it just keeps coming back, and it probably means there is an issue somewhere.
They also said that the radiator fan runs on high constantly. This I had noticed about 4 days before booking it in, it just started.
It came about as I start the car, the fan would kick in and run on low or medium, I thought it odd as it normally would only come on when hot or idling. After about 5 mins of driving the fan s
Starting issue astra j 2010 1.7 cdti
Hi could anybody help with my astra j starting issue.it starts very intermittantly when engine is warm will not start at all. Runs very well when aventually does start. I have changed glow plugs, fuel filter, but cant locate the fuel pump to see if that is an issue.had it to the dealer and they want to do a process of alimination which i cant afford...any ideas please help. Thanks shaun
Long short Ford Fiesta issue
So my wife came today with an issue on her car.
Every time you lock the car by fob or key the boot pops open and the rear wiper moves & there is no front wipers at all.
Ive checked all fuses relays cleaned up the ground points to no avail.
I searched Google and came across the boot button issue, so I've taken that all apart and it was all good.
I removed the neg of the battery for a few hours hoping systems would reset but no. I've checked the grounds with a multi meter and there are reading
coolant issue
Evening guys,
Ive been keeping an eye on my expansion tank for a while but yesterday I went to the the kids to nursery and was prompted with a low coolant level warning. So i checked to see where it was at and there was just under half when I always keep my tank topped up.
I took the cap off and started the car to see if there was perhaps an air lock in the system. Ran the car for about 10 minutes and held it at 2000 rpm for about 2 minutes. The level returned to normal.
Checked it a
Service Deterrent System Issue
Hi guys,
Quick question, this morning I had the service deterrent system message come up after 3 startups.
Now after reading many messages, this indicates that the battery is goosed.
My start stopto hasnt worked sinceout I bought the car about a month ago.
All this indicates battery from what everyone tells me.
So questions are which please help me with....
a) is it definately my battery that is knackered??
b) I have been advised that as its stop/start I need a gel battery.
c
JTC 1.4T (Automatic Gearbox) Downhill issue
Hello Experts,
Just wondering, Does any one here experience a wierd behaviour on Rev gauge while on a not so steep downhill?
Basically, i own an Astra GTC 1.4T Auto transmission and when i'm doing a downhill, (doing around 40 ~ 60 mph - rev around 2000 rpm) and apply brake to slowdown, the engine rev goes up to 3000 ~ 4000 rpm.  Is this kind of normal?
I asked few Automatic car drivers (Jaguar XE owner and a BMW 3 Series owner - all 65 plate), and they said they haven't experinced such
Drl issue
Hi guys after noticing my drivers side DRl not working I replaced  the bulbs. However the drivers side drl is still not working even though the sidelight is. Any ideas
