issue heater
Heater Issue
Hello All,
Strange fault on my Astra, the outside temperature gauge fluctuates wildly goes from -2 to +17 in a short time then back to say +4 before moving again, the heat coming out of the vents is almost uncontrollable too no matter the setting on either side heater control
The external sensor was replaced last year following a front end rebuild after a shunt
Any ideas please folks ?
Maybe a you're HVAC needs a re-flash, or it could be something more to do with the crash.
  DRL - sidelamp issue stajerad 1 4,343 12:th-Sep-2021, 15:37:54
  DRL/Sidelight Issue MassiveRoy 1 4,085 10:th-Feb-2021, 19:57:52
Last Post: Rhun91
  2 days and already an issue..... MrCrunchy 6 7,085 18:th-Sep-2020, 18:32:29
Last Post: MrCrunchy
  Aftermarket android H5754 headunit issue simpledun 1 4,980 4:th-Jun-2020, 09:17:15
  ASTRA J HEADUNIT ISSUE AstraJ_OwnerSK 1 4,621 10:th-Nov-2019, 08:31:13
  Sat Nav issue Slakky 3 6,282 2:nd-Sep-2019, 13:06:06
Last Post: vocky
  StabiliTrak/ABS Issue Desperado 1 5,908 17:th-Jun-2019, 09:31:05
  hatch issue Qaranc 4 9,294 2:nd-Jun-2019, 08:01:28
  Tailgate issue Qaranc 0 4,063 1:st-Jun-2019, 09:24:16
Last Post: Qaranc
  Start up issue... only once daveloz12 4 7,473 22:nd-Mar-2019, 10:02:26
Last Post: daveloz12
