issue j astra headunit
ASTRA J HEADUNIT ISSUE
I have a aftermarket head unit installed never had a issue for 2 years(was pre installed before purchase), its a Driveaudio Premium V2 with a cd400 stereo unit. Today I had installed some canbus led light bulbs, kept getting errors so have removed them since. I didn't realise until I needed to use my headlight that every time I turned my headlights on the rear camera would come on but says on screen no signal (camera works as should in reverse gear). I've disconnected the battery for about 15mintes but that didn't fix the problem. I'm just wondering if anyone has any suggestion to help fix this, maybe a fuse or relay but don't know where to start.
Thank you for any helpful advice.
Did you touch anything in regards to the radio?
Are all the lights working?
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,749 21:st-Oct-2024, 18:22:15
  DRL - sidelamp issue stajerad 1 4,357 12:th-Sep-2021, 15:37:54
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,663 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 15,124 6:th-Jun-2021, 18:25:04
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 9,045 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 6,962 12:th-May-2021, 14:29:50
  Astra j gtc modifications BillyBryan 2 5,543 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 5,405 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 5,514 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  DRL/Sidelight Issue MassiveRoy 1 4,093 10:th-Feb-2021, 19:57:52
Last Post: Rhun91
