No radio signal on android headunit
I have just replaced my cd400 with an android head unit from iceboxauto. Everyhthing is working great but can't tune radio, just searches but does not find any stations.
The cd400 had no signal issues. Does the DAB/FM antenna work for normal FM?
Add low-level tulp jack to headunit
I had installed my audio amplifier using a high/low-converter because the standard radio doesn't come with low-level RCA/tulp outputs. Disappointed by the signal quality I decided to see whether we could just grab the low-level inputs before they hit the amplifier in the headunit.
Bad news for me was that the unit is really hard to disassemble beyond a certain point. I couldn't get a view of the amplifier circuit until I removed the metal shield/frame on the backside of the unit. This was sol
shabba - Replies:
Headunit advice needed
I havent got a clue when it comes to changing/ purchasing the correct headunit for my car.
Ideally im looking for bluetooth (dont have presently) a unit with a usb port built in as my car doesnt have one of those either. Satnav and it has to have Android.
I have looked around the forms but its all double dutch to me.
I wouldnt even attempt to install this, so anybody recommend anywhere in the North East of England or North Yorkshire.
Looking at £500 including fitting?
My car is a 201
Android headunit
So I've now fitted my B5754.
Im just wondering witch apps everyone uses on there own headunit
Headunit Fascia help
I tried to fit my new pioneer AVH-z5000DAB into my Astra today.
Everything went according to plan except one thing.
[Image:
http://i65.tinypic.com/o6env8.jpg ]
It seems that the fascia doesn't fit as it should. Any ideas?
Sports Tourer DAB+ on Android Headunit
11 plate Tourer with CD400 factory option - now running an Android W072 headunit.
I have the factory DAB cables in the drivers footwell, so assume I have the lead that runs to glass aerial built in (drivers side in Tourer).
I know there is an amplifier that fits to this with FAKRA cable connector.
Wanting to know:
If the wiring runs from the footwell to the rear and location of plug in loom (above window, below trim etc).
If it is, can I use this cable (with an adapter loom up front, fr
ASTRA J HEADUNIT ISSUE
I have a aftermarket head unit installed never had a issue for 2 years(was pre installed before purchase), its a Driveaudio Premium V2 with a cd400 stereo unit. Today I had installed some canbus led light bulbs, kept getting errors so have removed them since. I didn't realise until I needed to use my headlight that every time I turned my headlights on the rear camera would come on but says on screen no signal (camera works as should in reverse gear). I've disconnected the battery for about 15min
prtklmb - Replies:
Aftermarket headunit malfunction
Anyone there having similar problem.
I had recently installed rear view camera that fits where the rear light is, just above the number plate (Astra elite 2011). All wires set up and camera triggers on when in reverse gear.
The problem - the button on the car stereo faceplate (Volume and option) & steering wheel control works perfectly prior the use of rear camera. Once I active the rear camera via the reverse gear the screen views the rear and after disconnecting the reverse gear the cam
Aftermarket Headunit with Infinty System
I bought one of those Tesla style headunits a year or so ago, tried fitting it but never managed to get it working properly so it's sat in the garage ever since. From memory (its been a while) all the connectors connected fine and it powered up etc, but there was two problems I could not fix
1. Bluetooth never seemed to connect up
2. The main one, I could never get sound to work. Back then I did do some reading up and found the amp needs switching on which meant connecting a wire from some
Aftermarket android H5754 headunit issue
Hi hope someone can help me ?
I purchased a h5754 head unit in 2018 and are still really pleased with my purchase ! , I have been playing with settings lately to try to get unit to stay on longer than 5 minutes when acc turned off which does not seem to be able to adjust !
[color=#000000][font=Verdana]Unfortunately during this process I have set default power setting to off - now I can not wake machine up
