issue hatch
hatch issue
i have a 5 door hatch and i find the hatch is digging into the rear bumper, is the boot hatch fitted wrong or has the car been in an accident and bumper is fitted too high
There should be a slight gap between.
Upload some pic's so we can see.
as rusty says, its hard to tell without pictures
it is possible that its had a small bump to the rear as this can sometimes distort the plastic bumper, even a small "nudge" while parking can cause this, usually fairly easy to sort.
I will if i can fathom how to up load them
(2:nd-Jun-2019, 01:55:24)Qaranc Wrote: I will if i can fathom how to up load them
Here you go this may help.
https://www.vxoc.org.uk/forum/Thread-How...hotobucket
  DRL - sidelamp issue stajerad 1 4,348 12:th-Sep-2021, 15:37:54
  DRL/Sidelight Issue MassiveRoy 1 4,087 10:th-Feb-2021, 19:57:52
Last Post: Rhun91
  2 days and already an issue..... MrCrunchy 6 7,094 18:th-Sep-2020, 18:32:29
Last Post: MrCrunchy
  Aftermarket android H5754 headunit issue simpledun 1 4,985 4:th-Jun-2020, 09:17:15
  ASTRA J HEADUNIT ISSUE AstraJ_OwnerSK 1 4,627 10:th-Nov-2019, 08:31:13
  Sat Nav issue Slakky 3 6,307 2:nd-Sep-2019, 13:06:06
Last Post: vocky
  StabiliTrak/ABS Issue Desperado 1 5,920 17:th-Jun-2019, 09:31:05
  Tailgate issue Qaranc 0 4,068 1:st-Jun-2019, 09:24:16
Last Post: Qaranc
  Start up issue... only once daveloz12 4 7,478 22:nd-Mar-2019, 10:02:26
Last Post: daveloz12
  Heater Issue StewieG 1 5,301 16:th-Feb-2019, 08:59:18
