Heater Panel LED Conversion
For anyone that wishes to change the colour of the SMD LED in the gear surround.
Tools required
Stubby Philips s/driver
Small flat blade s/driver
7mm socket
Fine tip soldering iron
Qty 14 805 10 x 0805 Blue LED (SMD) - Ultra Bright - UK - 1st Class Post | eBay and 1 PLCC-2 [url=http://www.e
Heater Controls
Here I have for sale the heater controls which I removed from my car last weekend, they're in mint condition and work fine
Make an offer if you'd like them
[Image: https://farm9.staticflickr.com/8700/1638...040b_z.jpg]
heater and blower panel
If anybody has any ideas I would be grateful. Today I have been changing over to an after market head unit. When I clipped the heater blowers panel into the new facsia , and reconnected the power to them they no longer work,no power at all. Is there a specific fuse to look for or have I some how blown the panel.
Rear Window heater not working..
Hi all, Have a GTC SRI 2011.
Had for about 4 months now but just noticed the rear window demister is not working, press the button, light comes on. but nothing.
Checked the fuse seems Ok, I am assuming its a bad connection or resistance problem, Or worst case scenario matrix buggered.
I tried to find where it connects but it all seems hidden :(
Heater fault
Hi unsure is this is the right section to post this. But I've been noticing my heater isn't performing as good as it used to. Could be perfect today and the next day doesn't seem to be getting as hot. Any solutions to this? The cars a 1.7cdti
P0030-00 HO2S heater control circuit sensor 1
Hi everyone
Been getting the SVS service message coming up with P0030-00 HO2S heater control circuit sensor 1
I’ve just replaced the lambda sensor for an identical part, cleaned the egr, throttle body and map sensor yet the fault won’t go away.
Any ideas of what this could be? Don’t really want to go to a garage and get raped of it could be this it could be that.
Many thanks.
Heater Issue
Hello All,
Strange fault on my Astra, the outside temperature gauge fluctuates wildly goes from -2 to +17 in a short time then back to say +4 before moving again, the heat coming out of the vents is almost uncontrollable too no matter the setting on either side heater control
The external sensor was replaced last year following a front end rebuild after a shunt
Any ideas please folks ?
