timing water belt and pump change
Timing Belt and Water pump change
Does anyone have a how to guide for changing the Timing belt and Water pump on a 2014 Vauxhall Astra 2.0 Diesel?
Engine code A20DTH - 17C48924LBS
  Astra A17DTF - Timing Belt or Chain? everson38 1 4,447 17:th-Jun-2021, 12:03:07
  Auxiliary Belt failure - cam belt change question David` 8 10,279 27:th-Aug-2020, 17:57:38
  Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too Acond 1 7,744 14:th-Aug-2020, 14:35:21
  Coolant pump 1.7 96kw? alexandrufalfan 6 8,255 9:th-Mar-2020, 13:30:03
Last Post: alexandrufalfan
  Timing locking kit help trevorgetty@aol.com 5 7,656 26:th-Jan-2019, 08:09:44
  Which water pump Ykrats 2 5,257 11:th-Jan-2019, 09:21:59
  auto transmission fluid change niteram 4 8,204 23:rd-Aug-2018, 10:00:48
  timing belt and water pump bigsadie 5 9,525 13:th-Nov-2017, 08:28:58
