coolant 7 1 96kw? pump
Coolant pump 1.7 96kw?
Hi there,
Does anybody know if there is any big difference between the 2 sensor water pumps that are on the 1.7 engine . Opel Astra J
The sensor pump from nr crt 8 is very expensive and very hard to find, i'm wondering if i can change it with nr crt 7 and also change the pulley as it's different.
Basically should do the same thing no?
I have attached a photo with the 2 water pumps
Thanks,
I would say they aren't interchangeable but that doesn't mean it can't be done. It would be a suck it and see.
acording to the description, no.8 is nls (no longer stocked) - use the partnumbers for no,7 and no.3
As above , I should have read that I'm a parts man lol
I had 25+ years in various parts departments of franchised dealers
(6:th-Mar-2020, 18:43:03)niteram Wrote: I had 25+ years in various parts departments of franchised dealers
Just completed my 35th year this year lol, as you with different franchises.
Ha , thanks a lot , i didn't know what NLS means, so it should be good.
Pff , i should start to dig into the online shops for the no 7 part.
The no 3 part has no sensor and mine seems to be an issue from the sensor , i cannot fit the one w/o the sensor as it will result the same issue as i have it now.
Thanks a lot.
  Coolant level Kiel0777 2 4,645 20:th-Apr-2020, 06:30:13
Last Post: Kiel0777
  Which water pump Ykrats 2 5,252 11:th-Jan-2019, 09:21:59
  Timing Belt and Water pump change Tarrymittens 0 5,078 25:th-Oct-2018, 16:08:39
Last Post: Tarrymittens
  timing belt and water pump bigsadie 5 9,519 13:th-Nov-2017, 08:28:58
