which water pump
Which water pump
Which water pump do I need been told there’s 2 for the a20dth engines. Is there an easy way to find out.
Thought the engine code was enough not so.
Any help would be awesome
Look the part number based your VIN from one of the sites in the below thread.
https://www.vxoc.org.uk/forum/Thread-loo...n-try-here
Saw you posted a pic with you reg so got the part numbers for you.
55568637 PUMP, ASSY., WATER £78.00 or the new part number
55488983 PUMP, ASSY., WATER £82.00
  Coolant pump 1.7 96kw? alexandrufalfan 6 8,252 9:th-Mar-2020, 13:30:03
Last Post: alexandrufalfan
  Timing Belt and Water pump change Tarrymittens 0 5,078 25:th-Oct-2018, 16:08:39
Last Post: Tarrymittens
  timing belt and water pump bigsadie 5 9,520 13:th-Nov-2017, 08:28:58
