how to change speakers
tucpal - Replies:
how to change gear knob number colours..
tucpal - Replies:
How to change drl and h7 bulbs
[align=center][Image:
This How to will Cover How to change the DRL BULB AND THE H7 BULBS.
Most will know How to Do this but it will Help those that Don't.
FIRST STEP.......
Left Hand side
Remove the Hose from the Air Filter then Pull the Air Filter Box out
and Place it some were Safe out of the way
your Air Hose may be at the Other end of the Air Filter
but do the S
How To - Change colour of gear gator stitching
I thought i would show you howto change the color of the stitching
I used a bright red pen, when its got a shadow on it, it looks maroon, when the sun is shining it looks bright red.
Colors that would work great:
Red.
Yellow.
Black.
Light blue.
Bright green.
Orange.
You will need:
Red Sharpie.
Patience.
All you need to do is to use the sharpie as a brush rather than a pen and paint each individual s
Gear surround LED colour change
For anyone that wishes to change the colour of the SMD LED in the gear surround.
Tools required
Stubby Philips s/driver
Small flat blade s/driver
Fine tip soldering iron
Qty 2 [url=http://www.ebay.co.uk/sch/m.html?_odkw=4040+smd&item=271177853516&pt=UK_BOI_Electrical_Components_Supplies_ET&_osacat=0&_from=R40&hash=item3f2375aa4c&_ssn=top-quality-tools&_trksid=p2046732.m570.l1313.TR0.TRC0.H0.X4040
Window switch LED colour change
HOW TO: Change colour of centre caps
So i didn't like the grey/silver color that the center caps are so i decided to wrap them. Any color is possible but i went for a subtle black.
You can spray them if you like but i dont have the time, skills, patience or equipment to do this.
Firstly you need to remove your wheels and push the center caps out from the middle.
2. You will see the chrome griffin is attached using 5 tabs, you need to s
Gear box oil, to change or not to change?
So your thinking of changing your gear box oil? Well... So was I. I wanted to know if there are any NOTICABLE benefits, only takes about 15 mins and will cost £25 for 2L(you need 1.5L for the 2.0 diesel but can only buy in 1L). Will do a how to later this evening but this thread is to chat about it. What's your opinions?
2nd year service brake fluid change
I'm coming up to my second year service which if I'm right means the brake & clutch fluid need to be changed.
I know the dealerships don't do it but I have my service done elsewhere (as I don't trust the dealer) so to get my lifetime warranty reactivated would I really need to change the brake fluid?
Or should I just buy a bottle of it and get my mechanic to tick it as done.
A20DTH - Replies:
Change of LED color in Speedometer
Hi Mates,
I changed the leds of the uplevel display in my speedometer, but just have a look
[ATTACH=CONFIG]193[/ATTACH]
I have made an instruction in how to disassemble the speedo, but only in german, you can find it here:
KLICK
