timing locking help kit
Timing locking kit help
Hi i am looking for a timing kit for my 1.6t a16let astra 2012 j series gtc.
It needs a head gasket change and maybe skim but need the timing tools first.
I see loads on ebay for the j series 1.0 1.2 and 1.4 but not the 1.6turbo.
I have found one lazer kit but says a16xht instead 1.6sidi so might be wrong one. the 40 ebay ones are usually what i use As this is a one time use i dont mind the cheaper kits if i can find them. I have a few cheapers kits and they do fine for non commercial use.
So any help or links appreciated really could do with this asap please thanks as always. T.
Sent from my SM-G960F using Tapatalk
There isn't a 1.0 or a 1.2L Astra J.
Is this any good cover 1.6 A16LET?
https://www.ebay.co.uk/itm/7PC-Engine-Ti...ctupt=true
(25:th-Jan-2019, 08:38:32)Rusty2009 Wrote: There isn't a 1.0 or a 1.2L Astra J.
I seen this one and seen it match the a16let code. Can someone comment for defo if the 1.6 and 1.6turbo is same setup for timing chain and therefore this kit is fine. I hope so it just does not say anything about the turbo model. But that may just be manifold and ancillary differences but cam and timing setup could be the same. If anyone knows for sure or can check the codes mentioned for the kit pins that would be great otherwise at that price i dont mind buying and checking lol. Tnx.
Could be worth dropping the seller a message.
(25:th-Jan-2019, 20:36:27)Rusty2009 Wrote: Could be worth dropping the seller a message.
Will do. Any chance u know of a good sticky or haynes manual or service guide for head removal and retiming on this engine type. Thanks
Ps i just found this same kit for half the price so just bought it anyway its too cheap not to... lol. https://rover.ebay.com/rover/0/0/0?mpre=...3237211675
The online workshop manual has some info.
https://workshop-manuals.com/vauxhall/as...0_luw_lfh/
  Astra A17DTF - Timing Belt or Chain? everson38 1 4,129 17:th-Jun-2021, 12:03:07
  Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too Acond 1 7,276 14:th-Aug-2020, 14:35:21
  Timing Belt and Water pump change Tarrymittens 0 4,874 25:th-Oct-2018, 16:08:39
Last Post: Tarrymittens
  timing belt and water pump bigsadie 5 9,151 13:th-Nov-2017, 08:28:58
