WHEELNUTS/ locking nuts
Hi to you all I'm after wheel nuts and locking nuts to suit Astra alloy wheels Anyone got any for sale or were to buy Big thanks in advance!!!
Service done but need new locking key
Service done. Had to pay an 1/2hr labour for them to untwist a brake pipe after I had new brakes done a few months back.
Was told he couldn't get the locking nut off as the key was rounded.
I would have thought anyone with some sense would have called me and told me about this and offered to sell me a new wheel nut key but no. He managed to u twist it without removing the wheel anyway.
Parts dept was closed when I picked up the car so does anyone m ow how much vx charge and is it a new key or d
Central locking huge problems
I own a 2012 Astra j and I have had a lot of problems recently with the car locking itself when the drivers door is moved. It has mainly been an intermittent problem, but now it happens 90% of the time I open the door. It does not matter if the car is: Running, Ignition on, or being unlocked; but when the drivers door is opened, the car will lock and unlock itself multiple times. Its causing me a lot of issues as I have already been locked out twice
If anyone else has had similar problems and kn
wheel locking nut washer
Hi all, a bit of a long shot but the metal washer that was inside my locking wheel nut key has gone missing making it near impossible to remove the wheel nut. I don't suppose either anyone has an old one knocking about (willing to pay for postage) so I can slot it in and get my wheels off? Thanks in advance
2012 ASTRA J Central Locking Issues
Advice required : any ideas as to why my 3 passenger doors simple will not open ( from inside or out ) , the locks pop when the remote central locking is pressed. But the doors are deadlocked shut [Image: https://static.xx.fbcdn.net/images/emoji.../1f621.png]?[color=#1d2129][size=small][font=
Engine Coolant and remote locking
I bought my car about 6 months ago, its only 5 years old and had less than 40k on the clock. At first I had two issues with the car, the engine coolant light was coming on even though it had just been serviced and remote locking with the buttons in the car was hit and miss, sometimes they'd work other times it wouldnt, same with taking the key out, it wouldn't automatically unlock the doors at times.
I took it back to lookers and they spent around 3 weeks in total with the car (lockin
Timing locking kit help
Hi i am looking for a timing kit for my 1.6t a16let astra 2012 j series gtc.
It needs a head gasket change and maybe skim but need the timing tools first.
I see loads on ebay for the j series 1.0 1.2 and 1.4 but not the 1.6turbo.
I have found one lazer kit but says a16xht instead 1.6sidi so might be wrong one. the 40 ebay ones are usually what i use As this is a one time use i dont mind the cheaper kits if i can find them. I have a few cheapers kits and they do fine for non commercial use.
Intermittent alarms and auto-locking
Hellpo any advice welcome
Monday night car suddenly started alarming(audio only no light) ,  I opened shut door started engine etc, and all cleared fora hour or so, then it alamed about 7 or 8 times going off every 10-20 mins,.
Called AA they looked plugged in compuer as saws some alrms , but couldnt be sure of cause although did suspect power sounde battery.
Left car unlocked for next 24 hours, no alarms , then overnight had an alarm about 4am, when I went to go to work, the doors has aut
Door locking
Anyone had a problem where there car won’t locked press and double press the lock button lights flash to say it is locked but try the door or the boot and they open
