to remove door trim how
How-to Remove Door Trim
How-to Remove Door Trim.
So first start by getting a trim tool and go about half way along the bottom.
Then work to left abit then to the right just use a twist method on the trim tool (be careful on the right side as there is a hook that can brake)
Then work your way up the trim go in from behind and again use a twisting method
Once the trim is off there is 3 screws that need to be removed as marked.
Once removed the trim will be lose
Get your trim tool and then get in behind the time and again using a twist method un-clip the bottom clip then just work your way up.
When you get to the top (around the door handle) you need to unclip top & bottom equally
On refitting start at the corner of the handle and work your way along then down.
good info there
  How-to Remove Airbag Steering Wheel & Buttons Rusty2009 49 45,250 9:th-Sep-2020, 00:40:49
Last Post: M222RJF
  How To: Boot Door Panel sheppy1 6 16,382 21:st-Aug-2020, 17:47:38
  How-to remove Instrument Cluster (IPC) Rusty2009 24 39,999 23:rd-Jul-2020, 11:21:25
Last Post: scrooge
help with interior A trim removal passenger pillar astra j stestrange82 3 6,901 20:th-Feb-2019, 13:45:22
  How to remove the center console & EPB switch tucpal 11 24,247 4:th-Feb-2019, 02:38:22
Last Post: DikoAJ
  How-to Remove Sun visors Rusty2009 10 20,064 25:th-Aug-2018, 21:40:03
  How to remove air vent trim Rusty2009 10 18,952 25:th-Aug-2018, 14:20:50
Last Post: mikeb7900
  How to remove door cards Rusty2009 112 82,940 9:th-Aug-2018, 09:57:13
Last Post: DNT
  Upgrade to alloy door pins tucpal 7 17,730 5:th-Sep-2017, 12:24:44
Last Post: Padster
  How to, Door Lock Catch Covers. Astra J. tucpal 10 12,374 28:th-Jun-2017, 12:58:56
