How-to remove front bumper from Astra-j (MK6 5 Door Facelift)
[align=center]How-to remove front bumper from Astra-j (MK6 5 Door Facelift)
Tools needed
*Trim tools
*Torx 10 bit
*Socket Set
The first thing you need to do is remove 3 torx 10 screws on each side of the wheel arch.
[Image: https://www.vxoc.org.uk/Images/rusty/How...mper/1.JPG]
Then there is small bolt where the bumper
How To Remove Rear bumper
[Image: https://www.vxoc.org.uk/Images/rusty/pos...mper/1.jpg]
Start by taking the rear lights off to do this there is a wingnut behind each light unit.
[Image: https://www.vxoc.org.uk/Images/rusty/pos...mper/2.jpg]
Then pull the light unit towards you then right or left (my
How to remove the head unit from the car includes Screen removal
How to remove the head unit from the car.
Includes Screen removal.
Tools needed
* Cross head screw driver
* 7mm socket
*Small slot head screw driver or paper scraper.
Here's how it look to start.
[Image: https://www.vxoc.org.uk/Images/rusty/pos...dio/00.jpg]
1. Remove the non-slip mat.
[img]https://
remove and upgrade SIDE REPEATERS
A Real nice and Easy Upgrade is to Remove and Replace
the Side Repeaters for the Dark Smoked look.
[Image: http://www.vxoc.org.uk/Images/tucpal/How...ters/1.JPG]
Here is the Standard Side Repeater for the Astra j 5 Door.
[Image: http://www.vxoc.org.uk/Images/tucpal/How...ters/2.JPG]
To Remove them from the Car all you Need is an old C
Howto remove glove box & Replace Pollen Cabin filter
How to Remove and Replace the Cabin Pollen Filter
for the Astra j and GTC.
STEP ONE.....
Pull out the Door Seal just by the side of the Glove Box
to gain Access to the side Trim so it can be Removed.
[Image: http://www.vxoc.org.uk/Images/tucpal/How...ebox/1.jpg]
Just Pull the side Trim away
to Gain Access to the 4 Bolts.
[img]http:
How-to remove Window trims & door mirrors
[align=center][Image: https://www.vxoc.org.uk/Images/vxoc%20as...x.o.c.jpeg]
How-to remove Window covers & door mirrors
Tools needed
*Trim tools
*Phillips Cross head
*10mm Socket
if replacing the mirror/s you will need to remove the door cards How-to Here.
So to start this is what we have (you may not have wind deflectors fitted).
[img]https://w
How to remove the center console & EPB switch
How to Remove the Centre Console & EPB Switch.
Yes This is a Big Job...
Step one.........
Remove the Radio surround Trim.
[Image: http://www.vxoc.org.uk/Images/tucpal/How...sole/1.JPG]
[Image: http://www.vxoc.org.uk/Images/tucpal/How...sole/2.JPG]
Step two......
Remove th
How to remove door cards
How To Remove Door cards.
Front
[Image: https://www.vxoc.org.uk/Images/rusty/Doo...ront/0.JPG]
The first thing you need to do is open the window/s and remove key.
Then you can start removing the door cards,
So get a small precision screwdriver and remove the cover on behind the door handle
[img]https:
How To remove the front courtesy light
[Image: https://www.vxoc.org.uk/Images/rusty/pos...ight/1.JPG]
1. remove the trim from around the light
[img]http://www.vxoc.org.uk/Images/rusty/post%20images/How-To%20front%20c
Remove or keep
[align=center]Well with the Sun starting to come out it's time to start thinking about cutting polishing and waxing the car, when I do it I'm thinking about removing the badges.
Been thinking about it for some time now, but comments below.
Side wing.
[Image: http://i124.photobucket.com/albums/p39/r...49adf5.jpg]
[Image: http://i124.photobucket.com/albums/p39/r...e578dc.jpg]
The rear
Standard
[img]ht
