to remove amp the center switch console epb how
How to remove the center console & EPB switch
How to Remove the Centre Console & EPB Switch.
Yes This is a Big Job...
Step one.........
Remove the Radio surround Trim.
Step two......
Remove the Trim
from the side of the Centre Console
one each side it just Pulls off.
step Three.....
Remove 4 10mm Bolts
2, at the Front and Two at the Rear.
Step Four.........
Remove the Upper Trim
one each side
Again this just Pulls off.
Step Five.......
Pull out the Storage Tray
and undo the Connector
and put it out the way.
Step Six.....
Unplug the Main Harness Connector
for the Centre Console it is Located on the Above Picture
On the Right Hand side.
The Centre Console is now Ready to be Removed from the car
Pull the Centre Console Up at the back & Pull it Away from the Dash
it has Two Clips at the Front
That need to come out as you Pull the Console back.
The Centre Console is Now out off the car.
Step Seven........
Is to Replace the EPB Button
Turn the Centre Console over
and Remove Three Torque Screws.
Step Eight......
Remove the Connector for the EPB.
STEP NINE........
Remove the Harness Clips under The Storage
Tray use some Pliers to Pull the Clips out.
Step Ten.............
You can take the Storage Tray
out of the Centre Console.
Step Eleven..........
Remove the EPB Button
just Push the Clips out at the Back
and Swap the EPB over for the New one.
That is it Job Done.....
Now just Put it all back Together
and you have a Nice New EPB Button.
It's a nice Cheap Upgrade & looks a lot Better than the all Black EPB Switch
but yes it is a lot of Work but well Worth it
if you Need any Help just ask Here.
Thanks for this mate! finally found a RHD centre console with arm rest and manual handbrake slot!!! coming soon so will follow your tut to get it installed
Its seems a long how to but really it is not that hard at all
Tbh it doesn't even seem that hard (famous last words ha). It just looks drastic as there's a lot to remove. Hope the console is intact and without issues as I got it suspiciously cheap! Haha
you may need to swap the loom over show some pics on here when it turns up mate
and we will go from there
(23:rd-Jan-2016, 22:59:40)tucpal Wrote: you may need to swap the loom over show some pics on here when it turns up mate
Will do mate! Cheers
Guess id just swap over whatever looms are on mine to the new one anyway wouldn't I?
yes mate best to do that
Awesome! Will post if I have any issues cheers dude
(23:rd-Jan-2016, 22:54:42)sheppy1 Wrote: Tbh it doesn't even seem that hard (famous last words ha). It just looks drastic as there's a lot to remove. Hope the console is intact and without issues as I got it suspiciously cheap! Haha
Haha it will be easier than you trying to drive up the road in snow.
Oooooo snap!!! Hahaha. I'm not gonna go near another lightly snow dusted Hill again in this thing! Lol
This is going to haunt you ever @sheppy1
Thanks alot. I spent 4 hours looking for any info on how to remove that brake button. +1 to your karma)
  How-to Remove Airbag Steering Wheel & Buttons Rusty2009 49 64,836 9:th-Sep-2020, 00:40:49
Last Post: M222RJF
  How-to remove Instrument Cluster (IPC) Rusty2009 24 60,867 23:rd-Jul-2020, 11:21:25
Last Post: scrooge
  Window lift switch GTC andyp 0 4,509 7:th-Apr-2020, 08:51:03
Last Post: andyp
  How-to Remove Sun visors Rusty2009 10 25,872 25:th-Aug-2018, 21:40:03
  How to remove air vent trim Rusty2009 10 28,278 25:th-Aug-2018, 14:20:50
Last Post: mikeb7900
  How to remove door cards Rusty2009 112 128,674 9:th-Aug-2018, 09:57:13
Last Post: DNT
  Howto remove glove box & Replace Pollen Cabin filter tucpal 43 68,073 18:th-Apr-2017, 05:33:21
Last Post: iphoneservice
  How-to Remove Door Trim Rusty2009 1 14,676 15:th-Mar-2015, 13:31:07
