Howto remove glove box & Replace Pollen Cabin filter
How to Remove and Replace the Cabin Pollen Filter
for the Astra j and GTC.
STEP ONE.....
Pull out the Door Seal just by the side of the Glove Box
to gain Access to the side Trim so it can be Removed.
[Image: http://www.vxoc.org.uk/Images/tucpal/How...ebox/1.jpg]
Just Pull the side Trim away
to Gain Access to the 4 Bolts.
[img]http:
How-to remove Window trims & door mirrors
[align=center][Image: https://www.vxoc.org.uk/Images/vxoc%20as...x.o.c.jpeg]
How-to remove Window covers & door mirrors
Tools needed
*Trim tools
*Phillips Cross head
*10mm Socket
if replacing the mirror/s you will need to remove the door cards How-to Here.
So to start this is what we have (you may not have wind deflectors fitted).
[img]https://w
How to remove the center console & EPB switch
How to Remove the Centre Console & EPB Switch.
Yes This is a Big Job...
Step one.........
Remove the Radio surround Trim.
[Image: http://www.vxoc.org.uk/Images/tucpal/How...sole/1.JPG]
[Image: http://www.vxoc.org.uk/Images/tucpal/How...sole/2.JPG]
Step two......
Remove th
Auto Finesse, Bouncer's & Dodo Juice goodies
Having a clear out of stuff... All unopened and unused:
[Image: http://i13.photobucket.com/albums/a260/j...batw8t.jpg]
Complete kit to detail your car from Auto Finesse here;
200ml Passion Wax - £45
500ml Finale Quick Detailer SOLD
500ml Imperial Wheel Cleaner SOLD
500ml Tough Coat Paint Sealant - £24
500ml Lather Car Shampoo SOLD
500ml Rejuvenate Pre-wax Cleaner - £
GTC discs & pads
Well time has come to replace all of mine & Vauxhall have quoted £535 + VAT... How does that compare you think? Or should I tackle this job myself?
Lubricants, Fluids & Torque wrench settings Petrol Engines
Lubricants & Fluids and Torque wrench settings Petrol Engines
Engine Oil
Capacity including Oil filter
[TR]
[TD]1.4 Engines[/TD]
[TD]4.0 L[/TD]
[/TR]
[TR]
[TD]1.6 Engines[/TD]
[TD]4.5 L[/TD]
[/TR]
[TR]
[TD]Difference between Min & Max on Dipstick[/TD]
[TD]1.0 L[/TD]
[/TR]
[b]Cooling System[/
Lubricants, Fluids & Torque wrench settings Diesel Engines
Lubricants & Fluids and Torque wrench settings Diesel Engines
Engine Oil
[TABLE=Capacity Inc Oil Filter]
[TR]
[TD]1.3 Engines[/TD]
[TD]3.5 L[/TD]
[/TR]
[TR]
[TD]??[/TD]
[/TR]
[TR]
[TD]1.7 Engines[/TD]
[TD]5.4 L[/TD]
[/TR]
[TR]
[TD]2.0 Engines[/TD]
[TD]4.5 L[/TD]
[/TR]
[TR]
[TD]Differen
Squeaks & Rattles
Hope this might help some of you.
Symptoms - Squeaks and Rattles
Rattle Coming From the Side Rail
[TABLE=Rattle Coming From The Side Rail]
[TR]
[TD]Checks[/TD]
[TD]Action[/TD]
[/TR]
[TR]
[TD]Check the brake lines.[/TD]
[TD]
Tap lightly on the brake lines and listen for a rattle.
Install plastic tie straps to secure the brake
Brake & Disc Upgrade
I have been noticing really bad brake dust all over my alloy wheels since purchasing my car and it looks horrendous not even a day after I clean my car.
I've been looking into replacing the brake pads with the EBC YellowStuff Pads:-
[Image: http://tapatalk.imageshack.com/v2/14/08/...811df1.jpg]
Front pads - £88.20
[url=http://www.ebcbrakeshop.co.uk/vauxhall-astra-16-20092013-ebc-front-yellowstuff-brake-pads-dp42065r_p23505876.htm]http://www.ebcbrakeshop.co
BMW 320 Day, night & race mode
