to lights door how ambient
How to ambient door lights
#51
Front and rear windows.
Rear are only controlled by the driver switch unit.
Thought is was different you run doth wires from the drivers door to passenger or you will have to push an led into each position on the driver switch till you find the correct positions but make sure the light switch is on
I'll have a look tomorrow but don't think the offline version covers the cascada.
Finally got around to doing this, I've got the strips ready to be wired up I just didn't have a drill to hand to drill through the back of the door pocket to poke the wire through; that'll be tackled tomorrow.
Cheers for the tut @Tucpal
[Image: 43dcdd51c130b94319ff839120080a76.jpg]
Oh and the parts were about £20.50 inc VAT
Wait until it's dark.... The difference is brilliant!
I'm currently at the girlfriends house, it'll be dark when I next go out, expectations are high aha!
I was shocked at the difference.
Looks great, well done! These are on my list at some point!
well done and well worth the effort
@bhalay207 you were right about them being better at night. Gonna do the strips tomorrow when I've got the drill
if you put the strips in as well they look much better
Did you drill into the back of the pocket to feed the wire through? I can't find any other way of hiding the wire
yep drill a small hole in the pocket
Cheers. It's on tomorrow's to-do-list. Getting impatient with these multicoloured footwell lights :(
ha ha you are doing good
Is that for the footwell lighting?
The drilling? No its for the door pocket lights, the multicoloured ones I mentioned are for the foot wells
Oooo, I've not thought about door pocket lights. How did you wire the ambient lights in? I crimped mine
I spliced them in and did a tap of solder and wrapped in electrical tape, I've just finished the door pockets today too (finally got access to a drill)
Oh wow very good mate, get a picture tonight when it's dark too please! What LEDs did you use for door pockets?
Cheers, and I will do, going to Hallowscream York Maze tonight so will get one then.
I used these from eBay;
Item number 281677994220
I rewired them though as the wires that came with it were too thin
Awesome thanks mate, I need to do this to mine! Looks great! I just dread fiddling with door card etc...
look much better they look very good at night
I didn't mess with the door card other than drilling a hole that you can't even see in the door pocket.
Tip: use a thin flat head screwdriver and poke that through there before you use the drill. Otherwise the drill moves everywhere and you can't get a footing to start the drilling
You can just heat up a screwdriver and poke it through the plastic makes life easier
Ah I got it mixed up with puddle lights, thought you had to take door card off. Definitely get this done at some point then
Night time pic
Looks good that does! Is it too bright?
Looks awesome mate! Thanks for the night time photo! Makes me want to do this even more now lol! These come on with lights right?
Nemo did you just use a strip of less in the pocket?
Nah it's not too bright, have to get used to it at first but it's fine. Drove from Bradford to York and back again tonight and everything was fine
@Tonto yeah they come when the sidelights/headlights are turned on.
@Rusty2009 I used strips, but took your advise and added bigger wires. I used these to be precise from eBay:
http://m.ebay.co.uk/itm/281677994220
(1:st-Nov-2015, 00:57:03)Nemo Wrote: Nah it's not too bright, have to get used to it at first but it's fine. Drove from Bradford to York and back again tonight and everything was fine
Cool I have loads of red and white strips so it looks really cool.
Thought you were going for a white and blue theme?
I have red front footwell lights I have got white in the door but TBH it's very dull and I got the brightest white LED I could find, I have blue footwell lighting in the rear.
I want to leave the white in until @Whelanuk has come down on the 14th as I know he is thinking of going white so it will give him a better idea of what it will look like.
I quite like the factory red, it makes the car feel cosy.
So you've got white in the door pockets?
How does the white look when it's used for puddle lights?
Get the rear pockets done now just with the strip lights in the pockets gives the rear some color
Not in the pockets as yet, It looks nice mate have a look my progress thread to see it.
I like the white. Only think putting me off a full conversion is not sure if they bright enough to for the CD400 screen.
Managed to find time to do the door pocket LED strips today too think there's a loose wire in one of them though as it was blinking as I was refitting the switch! Will have to take a look
Hmmmm maybe wiring is fine! Pulled everything out and played with each of the wires and gave them a cheeky tug and nothing blinked or went off or anything... Odd! Look great anyway and not too bring next up is same for rear! @tucpal did you ever make that tut? Sure I've asked you this before..
Edit: I also used the hot screwdriver method for making the holes and it worked great
Got pics from where you drill/pierce the pocket to add led strips please, they look really good mate!
Cheers got adive on it from @nemo which helped loads! Pics are pretty bad as didn't want them with flash on but ya get the idea haha. They're not at all distracting either. I'll try and get photos tomorrow, too dark now. Dead easy and you can just make the piercing where you like really...as long as the wiring side of the LED strip is pointing towards the back of the car...then ya just pull the wiring up through to the hole where the window switches are...no need to remove the door cards which is great
Yeah I thought door card removal was need but since it's not I'll def so this! Just got to get the door handle ones ordered lol!
I just taped into the headlight switch as in the how to ambient gear surround then ran a wire to the back doors pull the seat belt trim back to get access to the door loom boot cover remove door card and speaker pull wire into door drill hole in the door pocket and refit door card and fit strip light
Makes it sound so easy
Hahaha it really was easy enough, took about 45 mins all in. More photos anyway and the bottom ones sort of show where the hole was made and where the wiring was fed into it. Hard to show as couldn't get my phone into the pocket properly lol
That bottom photo is of me point it into the pocket and the black part of the car at the top is the window switch /arm rest thing on the door.
Those strips are fastened to the inside of the pocket using no more nails tape hahaha
Don't know if these help @Tonto but I tried to highlight where I drilled.
Second picture shows the path of the wiring, the green dot is the drilled hole and the red arrow is wiring
Ah awesome thanks guys, I understand what to do now going to get these ordered soon!
Looking good I have just made all the looms for door lights and gear stick on the insignia as it does not have them and I really miss them but they will be in the car in a day or two keep up the good work lads
I've ordered led strip for door pockets but want to check I definitely haven't got leds I'm door handle before I buy them. Any easy way to check?
  how to install FOOT WELL LIGHTS tucpal 136 94,120 22:nd-Feb-2021, 08:00:17
  Super Bright Boot Lights sheppy1 26 23,290 12:th-Nov-2020, 17:54:59
Last Post: Arkanggel10
  how too AMBIENT LIGHT AROUND THE GEAR GATOR tucpal 165 120,556 15:th-Oct-2020, 06:59:05
  Projector HID retro fit Astra j 5 door tucpal 88 82,340 4:th-Jun-2020, 09:01:15
  HOW-TO LED DRL Error free for the Astra-J 5 door tucpal 217 164,648 21:st-Sep-2019, 10:01:53
  How to fit courtesy lights in mirrors kyle-astra-j 21 20,926 18:th-Feb-2018, 06:15:13
Last Post: Leigh0274
  Upgrading Fog lights on J 5 door GarethMyers14 4 9,776 17:th-Nov-2017, 02:25:38
Last Post: sanj424
  How to Puddle Lights Rusty2009 22 27,557 6:th-Nov-2017, 20:16:44
Last Post: zzattack
  HOW TO LED TAIL LIGHTS tucpal 31 28,043 24:th-Oct-2017, 12:29:02
Last Post: Grimo72
  how to upgrade interior lights to SMD LED tucpal 91 62,936 2:nd-Aug-2016, 13:42:21
4 User(s) read this thread:
eatmybogbrush (24:th-Feb-2025, 22:45:55), jason_carter (26:th-Oct-2024, 09:04:28), carl_howells (12:th-Nov-2024, 19:30:05), jas7c5-2008 (28:th-Mar-2025, 11:20:26)
