How to ambient door lights
This is a How To for the Door Ambient LED Lights
There are now two Versions of this How to so this is Version one
Using the Correct LED but Taking Power
from the Window Switch Ambient Light Circuit
this means they will come on when you Open the Door
and go off when you Close the Door
and stay on when you Turn the Side Lights or Headlights on
i have my Lights wired like t
how too AMBIENT LIGHT AROUND THE GEAR GATOR
This is a how to for the ambient LED light
that goes around the Gear Gator using the Factory LED.
first step........
Is to Remove the Stereo Surround trim
for removal follow this.
How-to remove the head unit
[img]http://www.vxoc.org.
Retrofit gear stick surround ambient light
I have this plug but with only black and white wires.Will the gear stick ambient light work if i take the light and connect its own plug in this plug...I mentioned that there is 12v in this pair of wires
[attachment=172]
[attachment=173]
Gearstick Ambient Lighting
Hey All,
Does anyone need the ambient lighting module that goes around the gearstick? I'm about to have one and I won't need it so willing to sell on.
Help wiring ambient lighting
Hi all can you help me out I'm adding so ambient lighting to my doors I follows the guide on here but as you can see on picture below why cant I add wire from switch straight down the door (green line )
I don't understand the ( purple bit ) where you put wires through please can some one help pictures thanks in advance.
[Image: http://i.imgur.com/rukNCQD.jpg]
Admin can remove I have sorted it now thanks ??
Ambient lighting door LEDs [SOLD]
Gear stick ambient light [SOLD]
Ambient Lighting
Can anybody fit ambient lighting into my astra. All costs covered plus your time
Hey
I have an ambient light here for sale which has the connector from an auto transmission Astra J. You can however snip the connector off and wire it into the ambient light circuit yourself if you have a manual car.
Anyway, pics below and part number of believe is 13306445.
Looking for £25 posted.
Cheers [Image: https://uploads.tapatalk-cdn.com/2017101...527df7.jpg][Image: https://uploads.tapatalk-cdn.com/2017101...33f462.jpg]
Exterior ambient lighying
My lights dont come on when I unlock the car anymore. Ive checked the settings and they say it is turned on, but they dont come on anymore. Any idea why??
