pdc wiring diagram front
Front PDC wiring diagram
Hi. I need help. I want to retrofit front and rear PDC. I installed module, switch, rear wiring harness(bumper and loom to the module) and front bumper wiring. Now i need to make some custom loom, to connect front bumper harness to the car. I have connectors, i just need some wiring diagram, to know, where to connect wires. I know, that this loom connect under the battery to the other wirings, but anyone have some wiring diagram, to know where to connect which wire?
[attachment=1235]
[attachment=1236]
(8:th-Jan-2021, 20:03:55)milozic Wrote: Hi. I need help. I want to retrofit front and rear PDC. I installed module, switch, rear wiring harness(bumper and loom to the module) and front bumper wiring. Now i need to make some custom loom, to connect front bumper harness to the car. I have connectors, i just need some wiring diagram, to know, where to connect wires. I know, that this loom connect under the battery to the other wirings, but anyone have some wiring diagram, to know where to connect which wire?
Ignore the UDP sensors
  Retrofit front parking sensors (GTC) pedroc1999 3 2,380 27:th-May-2023, 23:46:17
Last Post: M.Duman
  Lowering springs identify front rear martinpe68 1 1,714 12:th-Sep-2021, 15:22:37
  Front suspension knock????? Sri~mike 10 8,140 22:nd-Dec-2020, 10:21:36
Last Post: M222RJF
  VXR Front Bumper onto a 5dr Bear 2 3,376 3:rd-Oct-2020, 11:48:59
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 2,658 12:th-Jul-2020, 07:37:10
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 2,818 25:th-Apr-2020, 07:41:05
  Can You Add Front Fogs to an Astra J? SAMW98SO 2 3,743 10:th-Apr-2020, 13:29:58
Last Post: SAMW98SO
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 7,435 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
  Astra j vxr front seat Custerz90 7 8,831 31:st-Oct-2019, 16:30:42
Last Post: marablind
  Front Brakes + Discs sizing everson38 3 3,073 12:th-Aug-2019, 10:53:27
Qaranc (21:st-Oct-2023, 10:35:51)
