PDC on VXR front bumper
Just ordered a complete VXR front bumper. It dosen´t have PDC option. PDC was not an option on the VXR.
Mine comes from factory with PDC. Has anybody fitted the PDC sensors in this bumper and where.
Maybe someone has a good idea how to fit the sensors.
All inputs are welcome.
2010 SRI front bumper with PDC
Looking for a front bumper for a 5dr 2.0 cdti 2010 SRI with parking sensor holes, preferably in grey, will get the paint code soon as still to buy the car from the other half. I'll also be looking for the grills if anyone has them, if not I'll be buying the irmscher grill anyway most likely
milozic - Replies:
Astra J GTC retroffiting PDC
Hi. I have a question. I want to retrofit OEM rear parking sensors (or rear and front) . I already bought PDC switch, wiring and everything, i only need modul. I have found a lot of modules on ebay, but there are many different partnumbers. So how can i know, which one is correct?
leeso - Replies:
Front PDC Wiring
Hi, does anyone know what terminals are in the X100 connector under the battery tray, (headlamp harness side male pins). I need to make some wiring to connect to the body loom to the PDC wiring I have so don't have to runs the wires to the boot. RS link to item if anyone has done this TIA.
milozic - Replies:
Astra J GTC PDC bracket
milozic - Replies:
Front PDC wiring diagram
Hi. I need help. I want to retrofit front and rear PDC. I installed module, switch, rear wiring harness(bumper and loom to the module) and front bumper wiring. Now i need to make some custom loom, to connect front bumper harness to the car. I have connectors, i just need some wiring diagram, to know, where to connect wires. I know, that this loom connect under the battery to the other wirings, but anyone have some wiring diagram, to know where to connect which wire?
[attachment=1235]
[attachme
milozic - Replies:
PDC module programming
Hi. I need help. I am trying to retrofit front and rear PDC to my GTC. Everything installed, now i need to programm module. I bought used module, so i need to change or delete old VIN number from module and replace with my VIN number. Any idea how that can be done?
