sizing discs brakes front
Front Brakes + Discs sizing
Hey guys.
I have Astra J GTC 1.7 62 Plate.
Need to change my front brake pads and discs. Do anyone know what size discs width wise my car needs?.
Howdy mate, most 1.7cdti's are 300mm, to be sure i can check with your vin
Retrofitted:
(11:th-Aug-2019, 14:49:34)Lansa Wrote: Howdy mate, most 1.7cdti's are 300mm, to be sure i can check with your vin
Thanks a lot matey. How can check with the vin is there website that tells you?
Info from another Astra Forum.
For Astra J GTC all engines:
Front brake discs: 321mm (except VXR: 355mm)
Rear brake discs: 292mm (except VXR: 314mm)
  Retrofit front parking sensors (GTC) pedroc1999 4 6,322 8:th-Apr-2025, 22:18:56
Last Post: johnny77
  Lowering springs identify front rear martinpe68 1 4,161 12:th-Sep-2021, 15:22:37
  Front PDC wiring diagram milozic 1 8,184 2:nd-Feb-2021, 09:33:19
  Front suspension knock????? Sri~mike 10 15,121 22:nd-Dec-2020, 10:21:36
Last Post: M222RJF
  VXR Front Bumper onto a 5dr Bear 2 6,545 3:rd-Oct-2020, 11:48:59
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,609 12:th-Jul-2020, 07:37:10
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 8,371 25:th-Apr-2020, 07:41:05
  Can You Add Front Fogs to an Astra J? SAMW98SO 2 9,529 10:th-Apr-2020, 13:29:58
Last Post: SAMW98SO
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 13,907 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
  Astra j vxr front seat Custerz90 7 16,912 31:st-Oct-2019, 16:30:42
Last Post: marablind
