to an can add j? you astra fogs front
Can You Add Front Fogs to an Astra J?
My 2011 1.7 CDTI Astra J does not have front fog lights, just the turn signals where the fogs would be. So can you upgrade and add front fogs to the Astra J?
Yes you can indeed, it would need a custom loom from fuse board to fogs, new headlight switch & then programming via VCI.
(10:th-Apr-2020, 07:31:01)Rusty2009 Wrote: Yes you can indeed, it would need a custom loom from fuse board to fogs, new headlight switch & then programming via VCI.
Cheers for that, bit more work than I thought but sure might be something to get done.
  Retrofit front parking sensors (GTC) pedroc1999 4 5,899 8:th-Apr-2025, 22:18:56
Last Post: johnny77
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,254 21:st-Oct-2024, 18:22:15
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,380 12:th-Sep-2021, 15:24:05
  Lowering springs identify front rear martinpe68 1 3,919 12:th-Sep-2021, 15:22:37
  Vxr bumper on 5 door Astra j Sh4rk2007 10 14,521 6:th-Jun-2021, 18:25:04
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 8,464 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 6,722 12:th-May-2021, 14:29:50
  Astra j gtc modifications BillyBryan 2 5,248 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 5,123 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 5,200 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
Toffel (11:th-Dec-2025, 14:25:33)
