How to add your photographs to the forum using Photobucket
How to add your photographs to the forum using Photobucket.
You want to include photos into your threads / posts on VX.O.C.
The best way to do this is via an image hosting site, this keeps the sites sever space down and allows you more control over your photos.
I recommend using Photobucket to host your photos, registrati
How to add a Connector
This How to Covers How to Wire a Male and Female auto Connector
This is Really the Best way to join wires
or Add an Accessory that can be Unplugged Easily if Required
In this Case i am Adding Connectors
to my Load Resisters for my LED DRL,S
as this will make Taking the Headlights out much Easier
this will Help with Most Lighting Retro Fits etc.
You can Always Twist
Is it possible to add a pull out cycle carrier
Is it possible to fit a pull out cycle carrier. Never seen one before not sure if its just non UK market but it would[attachment=592][attachment=593] be cool
Thanks for the add.
Hi all just came on to this site. Have Astra j 2.0 sti diesel. Really like it. Look forward to reading the posts and catching up with you guys.
how to add speaker
hello, everyone.
I need to know how to add a front center speaker in my Astra j, I have the S160 installed in my car.
thankyou...
Add low-level tulp jack to headunit
I had installed my audio amplifier using a high/low-converter because the standard radio doesn't come with low-level RCA/tulp outputs. Disappointed by the signal quality I decided to see whether we could just grab the low-level inputs before they hit the amplifier in the headunit.
Bad news for me was that the unit is really hard to disassemble beyond a certain point. I couldn't get a view of the amplifier circuit until I removed the metal shield/frame on the backside of the unit. This was sol
add DAB to navi950
morning
could someone please confirm if you need a different DAB unit to go with the navi950 unit , I have the ubt unit fitted but I see if im correct it needs a U4D unit that I can see from parts catalogue
any help appreciated
thanks
John
Can You Add Front Fogs to an Astra J?
My 2011 1.7 CDTI Astra J does not have front fog lights, just the turn signals where the fogs would be. So can you upgrade and add front fogs to the Astra J?
Which Is The Best Way To Add Multiple Photos?
As the title says really. Photos on my phone are to big to upload and photbucket isn't free any more? How do other people resize images on a phone or use another image sharing site?
Engine oil level low ,Add oil
Hi everyone ,interested to know if someone have had this issue before ,Yesterday i was on a motorway  , warning came on the dash board "engine oil level low add oil ,the first thing i did obviously was to check dipstick level and it showed the level was fine .I had already booked the car for oil and filter change this saturday before this warning ,last oil changed was 5K km /6 months ago.i did lot of short journeys last 2 months so decided to have it changed after 6 months as oil life  is sittin
