to an can add j? you astra fogs front
Can You Add Front Fogs to an Astra J?
My 2011 1.7 CDTI Astra J does not have front fog lights, just the turn signals where the fogs would be. So can you upgrade and add front fogs to the Astra J?
Yes you can indeed, it would need a custom loom from fuse board to fogs, new headlight switch & then programming via VCI.
(10:th-Apr-2020, 07:31:01)Rusty2009 Wrote: Yes you can indeed, it would need a custom loom from fuse board to fogs, new headlight switch & then programming via VCI.
Cheers for that, bit more work than I thought but sure might be something to get done.
  Retrofit front parking sensors (GTC) pedroc1999 3 2,404 27:th-May-2023, 23:46:17
Last Post: M.Duman
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,738 12:th-Sep-2021, 15:24:05
  Lowering springs identify front rear martinpe68 1 1,736 12:th-Sep-2021, 15:22:37
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,155 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 4,218 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 4,459 12:th-May-2021, 14:29:50
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 1,921 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 2,071 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 2,208 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 2,548 2:nd-Feb-2021, 09:39:35
