broken wheel stud
Broken wheel stud
Hello :P
The wheel change company I used managed break one of the wheel studs when they remounted my wheels. Is this possible to replace? or do you need to replace the whole wheel bearing?
From the looks on youtube from other car brands, it looks pretty simple, remove the disc brakes, knock the broken wheel stud out with a hammer, replace with a new wheel stud. Is this equally simple on a Vauxhall astra? Money is a bit thight so I would ideally do it myself if it's an easy job.
I've never paid any attention when having to change my hub.
But it's shouldn't be you having to repair it let alone pay for it they broke it so they need to fix it.
  Steering wheel angle, esp, power Steering smoky-jr 3 7,506 6:th-Jun-2021, 18:23:26
  Steering wheel from Astra K foxydimsi 2 6,909 1:st-Oct-2020, 06:49:56
  AC Compressor clutch broken rlievens 2 4,358 19:th-Sep-2020, 19:01:39
  Drivers seat broken trim Big Dave2 10 10,130 21:st-Aug-2020, 22:19:41
  GTC limited edition alloy wheel paint code Nathan191210 5 7,345 1:st-Aug-2020, 19:22:43
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,634 12:th-Jul-2020, 07:37:10
Broken crankshaft bearing Fadii13 1 3,695 29:th-Jun-2020, 23:02:51
  space saver wheel Gary13 5 7,288 24:th-May-2020, 19:02:57
Last Post: Gary13
  Squeak when turning steering wheel Rusty2009 12 25,532 12:th-Sep-2019, 21:45:35
Last Post: Boycey1969
  Lowering and wheel spacers twinpipes 1 4,396 28:th-Jul-2019, 08:43:33
