saver wheel space
space saver wheel
Hi All, I  am still after a space saver wheel for my 63 plate gtc ,I did purchase a new but second hand one & I thought great, but when I tried to fit it, the studs didn't line up, they was only a fraction out & didn't want to force the wheel on. I was told it came off a J GTC, so perhaps mine isn't a " J " but I didn't know there was a difference. Luckily I was able to return the wheel. I was also told that a s/saver from a Cascada  will fit , any help will be appreciated, thanks
Think larger engines/diesels are 115x5 stud holes, while smaller engines have 105x5 stud holes. Doesn't matter whether GTC, 5 door or sports tourer.
Hope this helps.
(22:nd-May-2020, 12:38:11)Gary13 Wrote: Hi All, I  am still after a space saver wheel for my 63 plate gtc ,I did purchase a new but second hand one & I thought great, but when I tried to fit it, the studs didn't line up, they was only a fraction out & didn't want to force the wheel on. I was told it came off a J GTC, so perhaps mine isn't a " J " but I didn't know there was a difference. Luckily I was able to return the wheel. I was also told that a s/saver from a Cascada  will fit , any help will be appreciated, thanks
Hi that made me stop and think, never tried to fit mine have just done that fits ok phew, my car is 2017 1.6 turbo 147kw ( 200bhp ish ) here is all the numbers of the space saver wheel, 400BTx17h2 IS25, 4170021 017 48029, 2170104, hope this helps
(22:nd-May-2020, 21:33:58)Wrightski Wrote: Think larger engines/diesels are 115x5 stud holes, while smaller engines have 105x5 stud holes. Doesn't matter whether GTC, 5 door or sports tourer.
Hope this helps.
GTC no matter engine are 5x115
5-door is where you get the diffreance in size 5x105 5x115
Full list here
https://www.vxoc.org.uk/forum/Thread-Wheels-and-tyres
Hope this helps.
Full list here
Thanks for the clarification Rusty
Hope this helps.
thanks for your reply, I can only assume the wheel I tried was a 5x105 & I need a 5x115
thanks for the info, yes its best to find out if the wheel fits on your drive & not on the side of the road at night & in the rain
  Steering wheel angle, esp, power Steering smoky-jr 3 7,052 6:th-Jun-2021, 18:23:26
  Broken wheel stud Euroshopper 1 3,537 6:th-Oct-2020, 07:08:18
  Steering wheel from Astra K foxydimsi 2 6,586 1:st-Oct-2020, 06:49:56
  GTC limited edition alloy wheel paint code Nathan191210 5 6,968 1:st-Aug-2020, 19:22:43
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,240 12:th-Jul-2020, 07:37:10
  Squeak when turning steering wheel Rusty2009 12 24,730 12:th-Sep-2019, 21:45:35
Last Post: Boycey1969
  Lowering and wheel spacers twinpipes 1 4,210 28:th-Jul-2019, 08:43:33
  Astra VXR heated steering wheel THEHITMAN 26 27,290 10:th-Mar-2019, 09:34:44
  Complete Astra J wheel nut set for sale richardhmorgan1 1 5,948 4:th-Jul-2018, 18:05:30
  insignia flat bottom steering wheel into astra j????? dogstroker 1 6,340 14:th-May-2018, 07:13:11
