gtc wheel alloy edition code paint limited
GTC limited edition alloy wheel paint code
Ive refurbed alloys in the past using a dremel, varying git sandpaper, filler, primer, paint and clear coats. Generally it has turned out well.
I plan to try to do the same to my GTC limited edition alloys soon. Originally I thought they where diamond cut due to the coloring and texture, but at closer inspection and a bit of sanding I believe them to be painted.
Example wheels
https://images.clickdealer.co.uk/vehicle...810321.jpg
Can anyone confirm that they are painted? or am I completely wrong.  Im looking for the correct paint code for the lighter outer sliver.
I'm sure the silver is one of the star silver paints.
Starsilver 3 I think
Thanks for the replies.
I have bought sliver star 3. Will test and post results
(12:th-Jul-2020, 07:47:38)Rusty2009 Wrote: I'm sure the silver is one of the star silver paints.
So I bought the hycoats star silver three. Tested it, it definitely isn't star 3. Star sliver 3 looks abit dark for the rim. Ended up sanding the test area down and polishing the metal and sticking a clear coat on for protection until i find the correct colour.
Apologies it should be star silver 1 not 3
  Code p242f-00 Ruzty 5 6,649 14:th-Jun-2021, 21:51:46
Last Post: everson38
  Steering wheel angle, esp, power Steering smoky-jr 3 7,129 6:th-Jun-2021, 18:23:26
  Astra J Fault code reader suggestions Euroshopper 1 5,178 22:nd-Feb-2021, 08:50:12
  Broken wheel stud Euroshopper 1 3,560 6:th-Oct-2020, 07:08:18
  Steering wheel from Astra K foxydimsi 2 6,659 1:st-Oct-2020, 06:49:56
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 6,308 12:th-Jul-2020, 07:37:10
  space saver wheel Gary13 5 7,033 24:th-May-2020, 19:02:57
Last Post: Gary13
  Squeak when turning steering wheel Rusty2009 12 24,868 12:th-Sep-2019, 21:45:35
Last Post: Boycey1969
  Lowering and wheel spacers twinpipes 1 4,242 28:th-Jul-2019, 08:43:33
  Astra VXR heated steering wheel THEHITMAN 26 27,647 10:th-Mar-2019, 09:34:44
