NIGHTCD - Replies:
VCI code
Anyone that can request VCI code for the tire preassure system on a astra j 2011?
Got my hands on a gm mdi unit..
RPO Code List
[align=center]
[Image: http://i179.photobucket.com/albums/w301/...5fce57.jpg ]
RPO Code List
The following table provides the description of the Regular Production Option (RPO) codes that are available on the vehicle. The vehicle's RPO list is printed on the Service Parts Identification Label.
[TABLE=]
[TR]
RPO
Description
[/TR]
[TR]
[TD]01A[/TD]
[TD]
Benjy - Replies:
Radio Code after Subwoofer?
Hi guys,
I'm a newbie to Vauxhall's and so far am loving it!!
About to go and attempt to fit my sub , just wondering if I'm taking the radio out, after putting it back in will I need to enter the radio code, as I don't have it yet, (need to ring the dealer)
Hope somebody's up still and able to help.
Discount Code - Chris Knott: VXA-191
Hi, here's a helpful reminder of this club/forum's unique access code which members should use when asking for any Chris Knott quote:
VXA-191
It helps us to make sure you get the full benefit of the special club/forum member rates we have on offer. And, if your forum receives income from us per policy it also helps us to know who to pay commission to.
[b]Don't forget also that if you receive a quote before 01 June 2016 you'll be entered in our
HIDS-Direct Discount Code
Hello VX.O.C Forum,
I've seen some of your threads regarding our products in your forum. I'm glad to see the success you've all had with our products in the DRL units and our Terminator HID kits in the new Vauxhall vehicles.
I have here a code for 10% Off most of the store. "VXOCExclusive" Things not included are things such as whole Air Suspension units and OEM parts. However our whole range of Bulbs/HID Kits/LEDS along with a couple extra parts and the likes are all acceptable on the co
Fault Code P24AC 1.7 CDTI
I have a 2011 Astra J 1.7 CDTI 96 kW A17DTF ecoflex and one Fault Code P24AC.
EGR Valve is fine. And also EGR Cooler Bypass Solenoid Valve.
[color=#333333][size=small][
Starie - Replies:
Fault code DTC P2458
Using op-com for the first time and found a fault code for what I believe to be the dpf anyone know why this could be showing ? Does it mean it the dpf needs to regenerate or because it's blocked or has a fault ?
Paint code Help
I'm having an issue finidng my paint code on the car (need a few chips touched in), I've seen there should be a sticker in the passenger or drivers side door shut, but I've checked and the only sticker is on the passenger side and just gives the tyre pressure, I've scoured the engine bay and cant see any sticker there either, is there a way to get the paint code from the Vin No. , or is there any other way I can confirm what colour the car is, its a blue colour but I think theres a few colours t
Breakdown Cover DISCOUNT CODE: FORUM5
BREAKDOWN COVER DISCOUNT CODE: FORUM5
Chris Knotts are offering you another discount this summer - £5 OFF our comprehensive UK Breakdown Cover .
The normal price is already low at just £63 for a single vehicle but you'll be able to pick it up for as little as £58 if you quote the promo code: FORUM5 online or on the phone when you arrange cover between now and the end of September.
Chris Knott's UK Breakdown Cover offers as standard:
- HomeStart
- Roadside As
P0128 Fault code
Hello all and thanks for reading this.
Daughters GTC has P0128 fault code and A/C off due to high temp with fan running on full speed & temp gauge on dash not moving above 50 degrees.
New thermostat fitted - (old one was passing a little when cold)
Symptoms the same.
Looked at the service manual pages - should I now be looking at replacing another sensor in the radiator?
Many thanks.
