clutch compressor broken ac
AC Compressor clutch broken
Hi Guys,
Its been a long time, which is a good thing I guess because it means I haven't had any problems with my car Smile
I have one now...
The spring that detaches the clutch from the AC is partly broken.
It's this part below. One of the 3 metal colored springs is broken in two. Because of this the clutch doesn't disengage well and makes a not so nice noise when the AC compressor turns itself off. AC works fine otherwise but I'm sure the clutch is wearing off way too fast now.
[Image: A-C-Compressor-Hub-for-Opel-Astra-J-Meriva.jpg]
Should be an easy fix (except it uses pentalobe screws but I'll find me a screwdriver somewhere) but I can't seem to find the part. I found and ordered one for a Astra H in hopes it would fit but its a few millimeters too large.
Can you guys help me find the part please? I should be shipped to Belgium.
Can't seem find it second hand as they will allways sell the whole compressor not just one part.
Astra J - 1.7 CDTI 110HP
Ok, strangely enough I did manage to find the right part on ebay now for a reasonable 35 GBP after shipping.
https://www.benl.ebay.be/itm/A-C-Compres...3645219761
Now I need to find 5-lobe Torx bits and hope the old part comes off when it needs too Smile
If anybody wondered, i got it fitted and fixed Smile
well done, good to know that this fixed it.
  Broken wheel stud Euroshopper 1 3,727 6:th-Oct-2020, 07:08:18
  Drivers seat broken trim Big Dave2 10 10,013 21:st-Aug-2020, 22:19:41
Photo Broken crankshaft bearing Fadii13 1 3,639 29:th-Jun-2020, 23:02:51
  Can't get in gear - clutch problem? klargon 0 5,174 9:th-Dec-2017, 16:21:11
Last Post: klargon
  Clutch adjustment/grinding gears dammfust 1 5,471 22:nd-Sep-2017, 00:03:22
Last Post: mw2299
  Astra J Clutch pedal loose abba34 6 13,050 16:th-Sep-2017, 00:11:26
Last Post: slavenK
  Astra Gtc 1.4t clutch problem Wayneofwolves 2 6,803 25:th-Feb-2017, 09:16:33
Last Post: Wayneofwolves
  Astra 1.6 clutch judder after being stuck in traffic tina r 3 12,291 6:th-Aug-2016, 23:13:10
Last Post: marcus
  I've broken Doris GOKIWI 2 5,362 22:nd-Jul-2016, 09:45:44
Last Post: GOKIWI
  Clicking clutch Nemo 12 14,644 2:nd-Mar-2016, 20:16:12
Last Post: bhalay207
