in 6 clutch being judder stuck after traffic astra 1
Astra 1.6 clutch judder after being stuck in traffic
Hi this is my first post ,my problem is that when the car is stuck in traffic when pulling off in first gear I have a clutch judder .I bought the car in Nov  15 the garage told me that it had a new clutch fitted the car has covered 5000 miles from when I bought it. I would be very greatful for any advice has it is rather annoying problem.The car is an Astra 1.6 sri 5 speed gearbox ,Thankyou..
Clutch judder is usually something like oil or some other crap somehow getting on the surface of the clutch itself and causing it to not grip properly or smoothly when engaging causing the juddering effect as it grips in part, then slips, then grips and so on.
It can also be caused by other parts of the clutch or flywheel being slightly out of shape usually from being just plain worn out or glazed to the point it's not getting consistent grip.
It's usually a sign your clutch/flywheel might need to be looked at/replaced at some point in the near future. If it's only minor or infrequent then it will likely not need urgent attention. In a newer car, or a make of car with a known problem in that area I would get it looked at sooner in case there is some underlying problem that is causing it.
As it has had a new clutch it should still be under guarantee from them so take it back as it is not correct
My Astra H 1.6 had that same problem as described by rusty. Once the car warmed up a bit, it disappeared
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,677 21:st-Oct-2024, 18:22:15
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,614 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 15,061 6:th-Jun-2021, 18:25:04
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 8,909 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 6,929 12:th-May-2021, 14:29:50
  Astra j gtc modifications BillyBryan 2 5,507 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 5,351 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 5,446 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 7,109 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 7,138 24:th-Jan-2021, 14:44:22
