Astra 1.6 clutch judder after being stuck in traffic
Hi this is my first post ,my problem is that when the car is stuck in traffic when pulling off in first gear I have a clutch judder .I bought the car in Nov  15 the garage told me that it had a new clutch fitted the car has covered 5000 miles from when I bought it. I would be very greatful for any advice has it is rather annoying problem.The car is an Astra 1.6 sri 5 speed gearbox ,Thankyou..
cd600 to 900 stuck
HELP has anyone got a working Navi 600 to 900 upgrade CD  they could post to me i am stuck half way through having burned the image iso but cannot find how to copy the dnl file to disc any help would be appreciated as the head unit is useless at the minute i followed the instructions but hasnt worked and its stuck on boot 5 many thanks.
Auto lights stuck on main beam?
Alright folks,
After changjng the LED colours in the headlight switch, I've found out main beam is always on.
I need to take it out again and make sure the switch is properly seated of course, but just wanted to check if there were any additional recommendations simultaneously.
navi 600 stuck in bootloader mode
Can anyone help me please.
I'm stuck in bootloader mode in my Insignia.
I was trying to upgrade from my navi 600 to navi 900.
If i cant get the upgrade ill have to replace the unit - can this be done and do i need to replace it all or just the cd or ?
Please help asap.
Matt
Android head unit stuck
I installed my v5754 recently and it's been working perfectly. However when I was driving along today with Google maps running and playing music from the microsd card (done that before many times without issues) when the unit froze. I pulled fuse 4 from the fuse box behind the glovebox to reset power to the head unit and now it's stuck on a recovery screen. None of the buttons move the selectio on screen so I can't choose either option. Help please![IMG]https://uploads.tapatalk-cdn.com/20180401/
Tailgate Stuck Shut and wont unlock HELP
Hey all,
Wonder if any of you can help us,
We had a little trouble with the tailgate not closing so i cleaned up the mechanism and sprayed it etc and it worked perfect for a few months, now its stuck shut.
The central locking is working fine except you cant hear the click in the tailgate, I checked the fuse and its fine.
I have all the plastics and trim off and for the life of me I cannot find the switch to open it manually.
Can any of you kind souls help.
TIA
Car key gets stuck
It happened to me lately that I am unable to remove my car key after I have stopped the engine. This is very recent. The only trick I found was to re-engage the key (switch on without starting), move back from P to D, then back to P again, and finally turn the key anticlockwise and it would then come out!
Any idea how to solve this permanently? Thank you in advance.
Kirsley
