window passenger electric working not
Electric passenger window not working
Hello all
I have a 2010 Astra J. A short while ago I had to remove the door card in order to replace a broken door check strap link. Job done, window switch reconnected, everything back in place.
But the passenger window only worked for a couple of days. So, disconnect the battery for 20 minutes, reset all the windows and everything okay. Again the passenger window ceases operation a couple of days later. Repeat as before. Two or three days later passenger window not working again. Does anyone have a solution to this as obviously I can't keep disconnecting the battery every few days.
Many thanks
I would check you haven't disturbed a wire.
Thank you Rusty2009.
I was beginning to wonder if that was the case myself. I'll take it apart & check.
  New AutoDipDown module for passenger mirror A20DTH 2 5,307 21:st-Oct-2022, 09:33:44
Last Post: rlievens
  Electronic handbrake not working Euroshopper 3 4,505 29:th-Jul-2021, 15:21:44
  Deadlock not working Jonika21 5 5,338 22:nd-Dec-2020, 17:37:08
Last Post: Jonika21
  Sat nav unit, from insignia? Not fully working? Macauleyh96 10 10,504 18:th-Aug-2020, 14:40:41
Last Post: DNT
  service parking assist and tpms not working kevinmcken1404 3 6,563 18:th-May-2020, 10:09:32
  passenger door deadlocked celrx 3 5,990 15:th-May-2020, 15:29:46
Last Post: paula9568
  Electric Window intermittent problem Stanhope 3 7,633 21:st-Mar-2019, 14:35:49
Last Post: Stanhope
  electric rear windows marky79 5 7,475 11:th-Jan-2019, 09:04:32
  GTC water collects under rear window Canasta 2 7,277 30:th-Oct-2018, 22:23:04
Last Post: marky79
  Headrest for middle rear seat passenger benawhile 7 10,110 12:th-Oct-2018, 07:10:57
cpeter53 (1:st-Apr-2026, 11:12:30), AstraJ_FIN (14:th-May-2025, 14:43:50)
