Working hours.....
Whats the worst hours you've had to work???
I've been working 6am-3pm today and now im back in from 10pm until 6am!!!!!
Im a IT technician at a bank, what about you guys?
Change Steering Cruise Control Not Working
I replaced the steering wheel with a more sporty, but also in leather ...
Unlike my old steering wheel cruise control are the keys that where there is a button to activate it where previously remained pressed and activated the white light in the instrument cluster now there are two that the more there is a spy "Lim ".
Before mounting check the wiring and is the exact same same same colors wires and same positions ...
But after it is assembled and tested I realize that I will turn over the whi
Rear Window heater not working..
Hi all, Have a GTC SRI 2011.
Had for about 4 months now but just noticed the rear window demister is not working, press the button, light comes on. but nothing.
Checked the fuse seems Ok, I am assuming its a bad connection or resistance problem, Or worst case scenario matrix buggered.
I tried to find where it connects but it all seems hidden :(
Astra gtc wiper and start stop not working
I have a 2012 astra gtc with 27000 miles. My service light is on however i do not need one as it has just been serviced however when the light is on my start stop wont work it just doesn't do it and my wipers will only work on the last highest settings thats it (my back one works fine) however the light in the past has turned off for the odd minute or 2 and everything works fine then but it comes back and they don't work again. I was wondering if anyone knew a solution or what the problem is. Th
Cruise control not working
Hi guys,
The cruise control is no longer working on my car or is temperamental intermittent problem. It used to be just an occasional thing now it has become more frequent. Basically you turn on cc, light turns white, then you try to engage cruise control it just not working anymore not turning green, tried all sorts of methods on the controls to get it to work but no avail.
I have read up it could be a number of things to cause it. It could be the actual cruise control switch on the steer
blowers intermittently working
ok guys my blowers work with ignition on but when i start the car they go off 90% of the time? sometimes come back on
if i have been driving for a while,when they go off the red lights on the controls all go off,when they work they work on all speeds
air con works ice cold ect,checked fuse seems ok,check wire to blower all fine,do you think it could be the panel?
AFL basic problem (bulb not working)
Just been out to check the AFL on my astra (had it a month but never been out in the dark ;-) )
Everything seemed to work AOK apart from the fact the main Beam Assist does not work as quick as I can do on my own (a few people flashed me :-( )  No worries on that score.
When I got back I had a look at the lights and found that one of them was not "on".  I is on the nearside.
It is the one nearest the grill - I have tried to attach a JPEG (only 228KB) but it will not let me
I have rea
Horn not working.
Just wondering if anyone knows how to fix the car horn on the Astra j. Pressing the steering wheel trigger but nothing happens.
Sent from my Pixel 2 XL using Tapatalk
Power loss and stop start not working
Hey guys
I have a 62 plate astra J 2.0 CDTI.
I have noticed a few things and wondering of could shed some light on things to check.
1) my rev needle is sitting at 500 revs (not sure if that is low and then at times it fluctuates.
2) when driving and trying to set off it just doesn't seem to have the same power. It's intermittent but at times the power just don't feel there
3) The automatic stop start doesn't work anymore, or shall I say majority.of the time it doesn't work and then here an
Rear driving light not working
The rear light drives side has stopped working. At first, I thought it was a bulb problem. Bulb ok. So the next thought that it must be the bulb holders. But check that on another car and on the opposite side. I've ruled that out as well. So it can only be the wiring or the plug itself. Can this be bought separately? Or is it a case of tapping into the wiring loom with a 2nd hand plug.
Regards
Kiippax
