window problem intermittent electric
Electric Window intermittent problem
Hi all
My passenger window has developed a fault on my GTC, sometimes it will work and sometimes it won't. It's the same with both door buttons but seems ok closing and opening from the key. When it does work the one touch closing wont work but it's all ok drivers side.
Any ideas before I shell out cash at the dealers?
You could try pulling the negative off the battery for 30-60 mins let all systems shut down then reset the window after reconnecting the battery.
(19:th-Mar-2019, 14:11:48)Stanhope Wrote: Hi all
I had similar issue with Pax side window control on my old Veccie.  I popped the switch unit out of the housing, carefully took it apart and cleaned the contacts. They had a fine dirt layer on them.  Rubbed them over with WD and never had another issue...
Phlyer Phil
Head In The Clouds
Mind In The Gutter
Thanks all, by taking the switch out and putting it back in it seems to have worked!
  Intermittent start, stalls after clock sweep no throttle response Jump to Latest Brendonm9477 5 8,731 5:th-Jan-2021, 13:55:10
  Electric passenger window not working Harposaurus 2 6,121 30:th-Sep-2020, 19:29:35
Last Post: Harposaurus
Sad Astra 1.7 CDTI fuel quality problem klajdi 0 4,270 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  Injectors or SCV problem? kartush45 1 4,953 11:th-Mar-2020, 11:08:58
  Intermittent alarms and auto-locking dawks 2 5,049 10:th-Nov-2019, 10:19:58
  Astra J self starting problem Jopo2311 8 8,840 16:th-Mar-2019, 10:29:33
  electric rear windows marky79 5 7,479 11:th-Jan-2019, 09:04:32
  GTC water collects under rear window Canasta 2 7,277 30:th-Oct-2018, 22:23:04
Last Post: marky79
  Help-2012 Astra J S model rear window demister button problem irishastraowner 14 19,526 26:th-Sep-2018, 23:50:59
Last Post: everson38
Sad Rear electric windows & front fogs problems... Griifter 18 15,717 30:th-Aug-2018, 20:01:30
Last Post: Griifter
cpeter53 (1:st-Apr-2026, 11:29:54)
