window gtc under water collects rear
GTC water collects under rear window
Hi Folks
I have a 2015 GTC 2.0 diesel auto. I noticed that water collects in the gap between the bottom of the rear window and the boot.
So when I open the boot after rain, quite a lot of water flows back out of here. Its not leaking into the car or anything like that, but im thinking it's eventually going to rust in there if water is pooling in there.
Also tried parking on a level surface to see if it made any difference, but water still pools in the gap.
Anyone else noticed this, or done anything about it?
yep my GTC is the same.
hi I had the same problem, I found the seal around the high level brake light was gone.
changed the seal and now all is good.
its worth a try............
  Lowering springs identify front rear martinpe68 1 3,900 12:th-Sep-2021, 15:22:37
  Astra J Rear Bench Seat Clip. MrScottyMan 1 6,861 24:th-Jan-2021, 14:44:22
  Electric passenger window not working Harposaurus 2 5,778 30:th-Sep-2020, 19:29:35
Last Post: Harposaurus
  Rear diffuser Elad1962 3 5,035 29:th-Sep-2020, 22:14:18
  BiTurbo Rear Bumper Dudderz 3 6,645 5:th-Jun-2020, 19:49:44
  Rear Bumper PN 13346637 Jonnymac07 1 3,846 13:th-May-2020, 14:56:05
Last Post: paula9568
  Rear brake pads and discs everson38 4 6,681 28:th-May-2019, 10:53:57
  Electric Window intermittent problem Stanhope 3 7,199 21:st-Mar-2019, 14:35:49
Last Post: Stanhope
  electric rear windows marky79 5 7,127 11:th-Jan-2019, 09:04:32
  Rear Light Replacement (Need Advice) A.ROD 2 7,275 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
