discs brake and pads rear
Rear brake pads and discs
Hey Guys
I have an Astra GTC 62 plate 1.7 diesel.
I need to replace rear brake pads and discs. I'm looking on Euro car parts and there are two types of discs and pads. Is there anyway of knowing which pads and discs are correct short of measuring it all and buying numerous variations?
Thanks. Any help appreciated
Info obtained from another Astra forum
Rear brake discs: 292mm
(except VXR: which are 314mm)
ECP should be able to tell you what pads relate to this size of disc.
Having had a quick look on www.autovaux.co.uk the parts are cheaper than from ECP.
(21:st-May-2019, 11:31:21)Big Dave2 Wrote: Info obtained from another Astra forum
Thanks davw really appreciated it.
Dabe you don't happen to know this info do you :
Does anyone know the:
1) Torque specs: Brake caliper bolts
2) Torque specs: Caliper Bracket bolts
3) Torque specs: Wheel bolts
3) Winding back rear calipers : Clockwise or anti clockwise
Pretty sure most of the answers to your question are here
https://www.vxoc.org.uk/forum/Thread-How...oval-5Door
  Lowering springs identify front rear martinpe68 1 3,919 12:th-Sep-2021, 15:22:37
  Brake pedal sensor learn. Richiew1986 0 2,886 22:nd-Jul-2021, 16:53:31
Last Post: Richiew1986
  Astra J Rear Bench Seat Clip. MrScottyMan 1 6,891 24:th-Jan-2021, 14:44:22
  Rear diffuser Elad1962 3 5,060 29:th-Sep-2020, 22:14:18
  BiTurbo Rear Bumper Dudderz 3 6,669 5:th-Jun-2020, 19:49:44
  Rear Bumper PN 13346637 Jonnymac07 1 3,869 13:th-May-2020, 14:56:05
Last Post: paula9568
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 7,953 25:th-Apr-2020, 07:41:05
  Front Brakes + Discs sizing everson38 3 5,875 12:th-Aug-2019, 10:53:27
  electric rear windows marky79 5 7,170 11:th-Jan-2019, 09:04:32
  Rear Light Replacement (Need Advice) A.ROD 2 7,296 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
