windows electric rear
electric rear windows
hi to you all and happy new year.
I have a 1.7td astra j estate and would like to change the rear windows to electric,
so can any one tell me what parts I need (with part numbers if poss).
and can any body tell me if the door cards from a 5 door hatch back will fit ????.
You will need the window mechc's with motors door looms (all doors)
You should have the wiring in place already if not it can be added.
They will also need programming via VCI.
I think the rear doors are slightly different to the hatch.
the rear windows of a tourer are a different shape to the 5 door, although the actual lower part of the doors are the same (the door skins have the same part number) (I used to work in a bodyshop parts dept)
(8:th-Jan-2019, 23:24:43)niteram Wrote: the rear windows of a tourer are a different shape to the 5 door, although the actual lower part of the doors are the same (the door skins have the same part number) (I used to work in a bodyshop parts dept)
so would you say the door cards are the same size......???
(8:th-Jan-2019, 16:26:48)Rusty2009 Wrote: You will need the window mechc's with motors door looms (all doors)
hi russ
do you mean looms for both rear doors or all four doors.
hi russ
Both rear doors.
Driver door as there more wires needed in driver door.
Passenger front door as it's wired slightly differently.
  Lowering springs identify front rear martinpe68 1 3,937 12:th-Sep-2021, 15:22:37
  Astra J Rear Bench Seat Clip. MrScottyMan 1 6,911 24:th-Jan-2021, 14:44:22
  Electric passenger window not working Harposaurus 2 5,832 30:th-Sep-2020, 19:29:35
Last Post: Harposaurus
  Rear diffuser Elad1962 3 5,080 29:th-Sep-2020, 22:14:18
  BiTurbo Rear Bumper Dudderz 3 6,691 5:th-Jun-2020, 19:49:44
  Rear Bumper PN 13346637 Jonnymac07 1 3,884 13:th-May-2020, 14:56:05
Last Post: paula9568
  Rear brake pads and discs everson38 4 6,763 28:th-May-2019, 10:53:57
  Electric Window intermittent problem Stanhope 3 7,272 21:st-Mar-2019, 14:35:49
Last Post: Stanhope
  Rear Light Replacement (Need Advice) A.ROD 2 7,314 17:th-Dec-2018, 19:17:48
Last Post: A.ROD
  GTC water collects under rear window Canasta 2 7,068 30:th-Oct-2018, 22:23:04
Last Post: marky79
