Gilmore - Replies:
passenger side wing miror
after a very long successful drive home from london to newcastle, i managed to smash my mirror off of post of garage door
anyone got one, or know where one is selling as cheap as possible
Passenger side door handle.
Need one as I scuffed mine "/ technical grey if possible !
tucpal - Replies:
How to stop Interior Trim Rattles from Passenger side area Astra J.
[align=center][Image:
This How to will Stop Rattles that Appear to be Coming from the Seat Belt or A Pillar Area.
For a while now i have a Wired Rattle that seems to come from the Passenger Side Area
Around the Seat Belt or A Pillar Area and i have not been Able to Put my Finger on were Exactly it has been Coming From
[img]http://i179.photobucket.com/albums/w301/tucpal/trim%20sp%20006_zpsbagsk
monkeez - Replies:
Rear passenger windows..heated?
I've had my GTC about 5 weeks now and i noticed when i picked it up that it had what looked like heating elements in the rear passenger windows.
Are these what i think?
cheers
Astra 2.0cdti sri puddle passenger floor
I have an 11 plate Astra 2.0cdti sri. I have been having problems with a puddle appearing on the passenger side floor. There are no other wet areas of the car, and it doesn't happen everytime it rains. I saw a youtube video of an older vectra that had the same issue and it was caused by a drainage cup? under the front screen getting clogged up. I think i might have the same problem as it doesn't happen everytime it rains. I had a look around that general area but as i know next to nothing about
DaPa - Replies:
Passenger Air Bag Light
This is illuminated when the daytime running lights are on, if I switch the normal lights on it goes off, is this correct?
DP
sheppy1 - Replies:
Passenger Side Silver Lake Mirror Cover
Hey All!
Anyone got or know where I can get a passenger side mirror cover in silver lake colour? Won one on ebay for driver side but can't find a passenger side one. Will resort to breakers only if I have too! Ha
This is what I won and need the one for the other side
[Image:
http://uploads.tapatalk-cdn.com/20160605...0edb91.jpg ]
Ta
Parts for passenger seat
I'm after the spring that goes on the adjuster handle of the front seats. It's the handle you lift to slide the seat backwards and forwards. The spring goes between the handle and the locking mechanism on the runner.
I'm also after the part numbers for the threaded torx bolt (I think it's an m6) and the nut the goes with it which bolts the runner to the seat frame.
Hopefully that makes sense?
Headrest for middle rear seat passenger
My recently purchased 2015 Astra J Hatch has no headrest for the middle back seat passenger.
Would anyone know of an aftermarket/retrofit accessory that can be fitted to do the job? I have seen these:
https://www.vauxhall-accessories.com/rea...ck-textile
but not sure if they would fit may car.
help with interior A trim removal passenger pillar astra j
Hi all hope I'm posting in the correct place
I need to remove the A pillar interior cover on the passenger side of my car to fit a dashcam and a few other wires for my new stereo
it doesn't have the airbag clip to flick out or a screw . I wondered if anyone knew a easy way to remove it before I yank it out and break it lol
