door passenger deadlocked
passenger door deadlocked
hi having a few problems with my astra j 1.3 td. the passenger door is deadlocked ive tried disconnecting battery still no joy.
managed to get the door trim off i can pull the door popper up and down and the door handle from inside but still no joy so assume something electrical is stopping me opening it. any help be appreciated as ive got so far dont want to give up!
hi have you checked the eletrical conection on the door
(14:th-May-2020, 19:54:23)paula9568 Wrote: hi have you checked the eletrical conection on the door
can i get at it with the door closed? is it behind the speaker?
sorry not sure,but if you take the door pannel of you should be able to themin side.to take the door off,take the chrome door trim offshould be 3 screw bhind it,then take the window control switch off,the small pannel behind the open close door lever,pop the door pannel off and force the pannel and slide it upwards,have a look on youtube to see how its done best of luck
  New AutoDipDown module for passenger mirror A20DTH 2 5,292 21:st-Oct-2022, 09:33:44
Last Post: rlievens
  Vxr bumper on 5 door Astra j Sh4rk2007 10 15,083 6:th-Jun-2021, 18:25:04
  Diesel door wont opel Arkanggel10 2 4,209 13:th-May-2021, 15:31:33
Last Post: Arkanggel10
  Electric passenger window not working Harposaurus 2 6,114 30:th-Sep-2020, 19:29:35
Last Post: Harposaurus
  door drain grommets bigbadkes 2 4,835 28:th-Aug-2020, 19:45:49
  1.6 cdti 5 door exhaust tip? h4r7y 1 4,691 17:th-Jul-2020, 06:47:38
  Door locking Flick19191 1 3,667 22:nd-Nov-2019, 09:40:18
  Replacing door check strap robk999 5 10,560 7:th-Feb-2019, 21:27:33
  Headrest for middle rear seat passenger benawhile 7 10,097 12:th-Oct-2018, 07:10:57
  Astra J 5 door facelift bumpers Iaintruten 5 8,182 30:th-Oct-2017, 16:40:35
Last Post: Iaintruten
