door drain grommets
door drain grommets
Hi I have noticed that most of the grommets are missing or badly blocked up is it best to leave them out or shall I replace them all as my drivers door tends to get a lot of water in it when it rains and were could i find out the part number for the grommets or a good place to get some from please many thanks for your help
(28:th-Aug-2020, 14:16:05)bigbadkes Wrote: Hi I have noticed that most of the grommets are missing or badly blocked up is it best to leave them out or shall I replace them all as my drivers door tends to get a lot of water in it when it rains and were could i find out the part number for the grommets or a good place to get some from please many thanks for your help
i just take them out a couple of times a year and wash them and put them back with a little bit of vaseline rubbed into the rubber to keep them supple.
I've taken all mine out, (well a couple were missing anyway)
I wondered why my osr door often had a puddle under it when I parked it at work, well that door did have a grommet fitted that was partially blocked so when it rained it didn't drain as quickly as the other rear door that didn't have a grommet.
seemed easier to remove them and the water out quickly rather than having it pool in the door.
  Vxr bumper on 5 door Astra j Sh4rk2007 10 15,061 6:th-Jun-2021, 18:25:04
  Diesel door wont opel Arkanggel10 2 4,196 13:th-May-2021, 15:31:33
Last Post: Arkanggel10
  1.6 cdti 5 door exhaust tip? h4r7y 1 4,678 17:th-Jul-2020, 06:47:38
  passenger door deadlocked celrx 3 5,964 15:th-May-2020, 15:29:46
Last Post: paula9568
  Door locking Flick19191 1 3,665 22:nd-Nov-2019, 09:40:18
  Replacing door check strap robk999 5 10,551 7:th-Feb-2019, 21:27:33
  Gearbox Oil drain plug? shabba 13 15,908 10:th-Jan-2018, 11:59:11
Last Post: stigeye
  Astra J 5 door facelift bumpers Iaintruten 5 8,163 30:th-Oct-2017, 16:40:35
Last Post: Iaintruten
  5 door drl to led rfoster88 3 8,175 3:rd-Oct-2017, 16:58:03
Last Post: rfoster88
Smile Astra J 5 door Facelift diffuser MandaJ88 0 5,895 27:th-Sep-2017, 13:14:37
Last Post: MandaJ88
