6 door tip? cdti exhaust 1 5
1.6 cdti 5 door exhaust tip?
I wonder if anyone else has wanted a visible exhaust tip for their 1.6cdti 5 door? On the 2.0 cdti you can see the exhaust under the rear bumpers valance, does anyone know if its easy to swap over from the 2 litre car? Or could i just buy the bumper insert and a backbox after that? (Im led to believe theres little point in getting anything performance related for a diesel exhaust?)
Thanks in advance!
If you know the size of your pipe here are the sizes of the 2.0cdti pipe into the backbox is 55mm & from backbox to tail pipe it's 65mm.
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,739 21:st-Oct-2024, 18:22:15
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 7,655 12:th-Sep-2021, 15:24:05
  2.0 CDTi Auto Gearbox Oil Change Dennis S 0 4,303 13:th-Aug-2021, 14:29:25
Last Post: Dennis S
  Vxr bumper on 5 door Astra j Sh4rk2007 10 15,113 6:th-Jun-2021, 18:25:04
  Diesel door wont opel Arkanggel10 2 4,236 13:th-May-2021, 15:31:33
Last Post: Arkanggel10
  Astra J 1.4T Exhaust help sammpennington 1 6,954 12:th-May-2021, 14:29:50
  GTC exhaust options johno1412 1 4,950 12:th-May-2021, 14:26:49
  Astra J GTC 2.0 CDTI A20 DTH Stage 1 Remap - Wayside Performance M222RJF 8 11,571 11:th-Sep-2020, 20:55:21
Last Post: badger64
Sad Astra 1.7 CDTI fuel quality problem klajdi 0 4,282 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  door drain grommets bigbadkes 2 4,859 28:th-Aug-2020, 19:45:49
