niggle warning tyre pressure
Tyre Pressure Warning Niggle
Im after some guidance.
Front OS got a flat this morning.  When I replaced the wheel  and started her up to come home the dash pressure warning display is lit, but the pressure display screen is showing the front NS flat not the OS.  The thing is up on the jack so theres no way you can misread it....
Anyone know how this thing works?
15 plate 2.0 CDTI
Phlyer Phil
Head In The Clouds
Mind In The Gutter
(21:st-Mar-2019, 13:29:47)phlyer Wrote: Im after some guidance.
15 plate 2.0 CDTI
Hi something to do with resting the tpms system page 230 in the owners manual don't understand it myself have been told you can do it without the tool just be resting the disply?
Do you mean resetting rather than resting.
There is 2 systems one being manual and one being auto learn.
Pre 2014 is auto after 2014 is manual so the tool is needed.
I'm guessing the wheels were not swapped around?
(22:nd-Mar-2019, 11:43:56)Big Dave2 Wrote: Do you mean resetting rather than resting.
Whoops yes resetting
  coolant pressure tester chuzzle359 0 3,247 14:th-Apr-2021, 18:23:08
Last Post: chuzzle359
  Check Number Plate Lamp Warning mp21 10 15,145 10:th-Nov-2020, 23:33:17
Last Post: Galway11
  Glowplugs with pressure sensor or not Euroshopper 3 5,465 2:nd-Nov-2020, 16:01:21
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 13,307 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
  DPF pressure sensor richardhmorgan1 3 6,793 24:th-Sep-2019, 20:08:31
Last Post: Saunter
  Tyre sealant Telsun 4 5,454 23:rd-Feb-2019, 13:28:50
  Cracked tyre valve with TPMS Craig2305 5 7,407 5:th-Oct-2018, 13:31:48
Last Post: Craig2305
  A/C pressure sensor location scotchmist67 0 4,170 2:nd-Aug-2017, 10:04:34
Last Post: scotchmist67
  Fitted rear led lights, now bulb warning issues twinpipes 3 7,822 27:th-Jul-2017, 21:02:41
Last Post: Hummelshøj
  Airbag Warning Message sheppy1 7 11,649 25:th-Sep-2016, 21:23:20
