with tyre valve cracked tpms
Cracked tyre valve with TPMS
Hi all
I went to put air in my tyres today and noticed that the metal valve is cracked on one of my wheels and therefore I am unable to put air in. Is this a cheap tyre shop job or will the whole sensor need replacing?
Thanks very much
I would say a whole new sensor but forget buying cheap ones off ebay unless they are 100% genuine.
I got one from Vauxhall about 6 months ago and I was £45 I fitted it myself and then it had to be reprogrammed in the car.
(5:th-Sep-2018, 21:00:45)Htid Wrote: I got one from Vauxhall about 6 months ago and I was £45 I fitted it myself and then it had to be reprogrammed in the car.
It depends which type you have as there are two systems one is auto learn, the other is manual learn.
Manual learn needs the tool to wake them up, also the tool is needed if you move the sensors around.
Auto learn you don't need the tool it will wake up after a little time and you can also move them around freely.
Manual learn came in around 2014 so 14-64 plates on-wards would more likely be fitted with this system
the outer metal nut is only a few quid from the dealers
the TPMS sensor is about £55
Hi everyone. I bought the valve from eBay for £7 and Kwik fit fitted it for free
  Fuel Shutoff Valve NuttySqurill 1 3,719 12:th-Aug-2020, 07:58:08
  service parking assist and tpms not working kevinmcken1404 3 6,535 18:th-May-2020, 10:09:32
  Tyre Pressure Warning Niggle phlyer 4 7,947 23:rd-Mar-2019, 11:39:36
Last Post: andyp
  Tyre sealant Telsun 4 5,624 23:rd-Feb-2019, 13:28:50
  TPMS Sensors on wheels but not on car AphoticSketch 2 6,136 7:th-Nov-2018, 17:01:44
Last Post: AphoticSketch
  TPMS came on unexpectedly. shabba 11 12,329 28:th-Jan-2018, 16:28:26
  Dump Valve jamoes009 1 5,699 17:th-Mar-2017, 23:00:19
Last Post: Wayneofwolves
  EGR VALVE, MAP SENSOR, MAF SENSOR, THROTTLE BODY NEED TO IDENTIFY caretaker 2 8,113 16:th-Aug-2016, 15:22:22
Last Post: caretaker
  Tyler valve blow up Daz21 6 9,024 12:th-Aug-2016, 20:08:16
Last Post: Daz21
  Tyre choices 18" wheels andy2174 6 12,705 15:th-Apr-2016, 17:14:13
Last Post: andy2174
